Borg warner 4 speed
Hi, I just bolted up a 4 speed borg warner to my 69 camaro small block only to find out that the shifter rods hit the side of the transmission tunnel. I had the tranny in my 79 T/A which worked fine. I was kind of surprised because the tunnel in the 79 T/A is more narrow than my 69. I cut the hole in the tunnel myself (it was previously an automatic colomn shift) and everything lines up fine except for the rods. The shifter is not set up for a first gen camaro but i like the feel and placement better anyways. Can I turn the rods over and use them the other way? I think they would clear the tunnel but would that work? Or does anyone know where (besides salvage yards) I could get a set of rods that would clear the tunnel and be a direct fit to my tranny? Thanks in advance.
Hi,
I think you can fix it with a big transmission tunnel fabricating hammer. Rich |
Trans tunnel
If you put the shift levers the other way you reverse the shift pattern
ask me how I know.... |
rods
Is it just the end of the rods hitting???
Are the plates that bolt to the trans hitting also??? Keith |
| Replacement T5 Borg Warner gears | x711 | Transmission - Rearend | 1 | 12-16-2006 09:26 PM |
| Borg Warner T-10 ID - Ford | snakestang | Transmission - Rearend | 1 | 08-07-2006 09:40 PM |
| Borg Warner 4 speed I.D. | Dave Y. | Transmission - Rearend | 1 | 06-18-2003 10:25 AM |
| Replacing Borg Warner T10 with Richmond 6 speed | beazil | Transmission - Rearend | 3 | 05-16-2003 08:59 AM |
| Borg Warner T 56 | Silver | Transmission - Rearend | 1 | 05-13-2003 09:22 AM |
