gear ratio /borg warner 4-speed
hey!! can anybody help me on the gear ratio for a borg warner 4-speed trans
borg warner 4-speed
guys i'm trying to make sence of why it's not lining up...here's everything i got...borg warner 4-speed,main casting date 6-17-81, casting # 13 04 065 903 w.g. div,mlt 883,1cl132542...help me please!!
borg warner 4-speed
hey guys thanks for all the help !!! it helped alot !!!!!
What do you expect? You're too lazy to give us any info, you won't do your own checking for yourself, come on!
There are at least 7 different sets of ratios it could be, and the easiest way of checking in-car is checking tach against MPH in each gear. Out of car, put a vise-grip on the input splines, put another on the output splines, and check each gear. Did you bother to provide us any of this? Nope. How about it's original application? You couldn't be bothered to tell us that, either. You must do your part before expecting anyone else to help. |
I'll be concise. Whats stamped or cast into the outside of the case has literally no bearing on whats INSIDE the case. Generally, most BW parts are functionally interchangeable with other ratios from Borg Warner. Heck you could have a 2 speed gearset in a 4 speed case.
Certain brands (AMC and even Mopar along with Ford) used similar but different ratios to whats currently available as the 'Super T10' |
The bigger issue for my figuring ( but not the driving experience ) is that 2.88:1, is it really 2.875:1? With B-W not giving tooth counts, there's only one ( costly ) way to know ( buy one ) |
borg warner 4-speed
hey "whyholdback" do you always talk so rough to a lady ? this is my first transmission. just trying to get all the info i could . i found the gear ratios for the t10 and because of all the help i knew where to look on line. thanks for everything ...and i'd rather be under a hood than on a computer...thanks guys
| 95 borg warner 5 speed to 81 305 | 81 monte drifter | Transmission - Rearend | 1 | 04-22-2007 04:57 PM |
| 4 speed, borg warner | Nova Boy | Transmission - Rearend | 2 | 11-22-2005 08:46 AM |
| Borg Warner 6 speed | Bmcelhinn | Transmission - Rearend | 2 | 01-22-2004 10:44 AM |
| Borg Warner 4 speed I.D. | Dave Y. | Transmission - Rearend | 1 | 06-18-2003 10:25 AM |
| borg warner 4 speed | 4doorjoe | Transmission - Rearend | 1 | 01-07-2003 07:25 PM |
