Borg Warner 4- Speed TRans - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2008, 06:14 AM
I Need Information On Older Borg Warner T-10 4-Speed TRan Gear Ratio
Old 06-03-2008, 10:37 PM
Start by giving us the make, model, year, numbers off the case and the aluminum tag on the tailhousing bolt. Then, we'll be able to help
The most common early T10s had 2.54, 1.92, 1.51, 1.00. There were some Corvettes, Studebakers and AMCs which used close-ratio gear sets with a 2.20, 1.64, 1.31, 1.00 low and a few others with 2.32 low.
thnx, jack vines
Old 06-04-2008, 12:29 AM
http://www.dandltransmission.com/borgratio.html
Need Shifter for Borg Warner T-10 65fstbk Transmission - Rearend 3 04-09-2007 11:33 AM
65 galaxie 3 speed manual trans junkyardjeff Transmission - Rearend 4 06-24-2006 06:06 AM
Ford y block 4 speed trans RetroJim Transmission - Rearend 3 05-26-2006 05:59 PM
5 speed borg warner trans specs martion Transmission - Rearend 3 11-23-2005 05:11 PM
qyestons about a 3 speed trans chevellenut Transmission - Rearend 5 12-13-2003 10:39 AM
