Borg Warner 4sp identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2010, 12:37 AM
62SS409
I need some help identifying a 4sp which is in a 62 Impala I am restoring. It has the following info on it and I am trying to determine what it is and what it came out of. Any help is appreciated.
Stamped into the pad is 19L524005
Other info on the case:
8.31.78/1
MLT7802
1204065903
WG Div.
FpC4
Has 3 grooves on the clutch spline
Thanks
62SS409
Old 12-27-2010, 07:19 AM
thats a T10 of some variety but your number is most definitely 1304 not 1204.
You can use the PDFs on autogear.net under high performance to tell you what you have. Identifying transmissions after 50yrs by the grooves is tricky. If it was ever serviced and the input was replaced, it may or may not have the correct grooves. We usually open the sidecover and count the teeth on the clustergear (countershaft gear). Good luck.
Old 12-27-2010, 04:34 PM
62SS409
T-10 Identification
Thanks- I will pull it off and check the gears. Judging by the date on the case I think it is out of a 78 model vehicle.
62SS409
Old 12-28-2010, 01:29 AM
junior stocker's Avatar
I think your "903" trans is a 3.42 first gear Super T-10 model.
Old 12-28-2010, 09:33 AM
62SS409
Thanks.
62SS409
Old 12-29-2010, 02:57 AM
3rdmember
this any help to ya?
http://www.dandltransmission.com/borgratio.html
borg warner t10 dean652 Transmission - Rearend 3 08-24-2010 02:59 PM
borg warner or t 14?? 53fordguy Transmission - Rearend 1 04-12-2004 02:53 AM
borg warner 69at16 Transmission - Rearend 0 03-16-2003 01:02 PM
Borg Warner Identification cruiserlck Transmission - Rearend 1 02-16-2003 10:45 AM
Borg Warner T-10 fred56 Transmission - Rearend 2 11-02-2002 06:02 PM
