is this a borg warner 76 or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2012, 08:36 AM
old yukon's Avatar
Hi Guys
Im having trouble getting a rebuild kit for my rear differential.
its a GU4 rear axle ( 3.08) with IRS, from a 1999 lumina 3.8L AT
here is a similar diff, not mine
thanks in advance to anyone who can help id this diff, so that I can order a reuild kit !
Old 08-25-2012, 08:48 AM
big gear head's Avatar
High Performance Rear Ends
That's a new one on me. I've never seen a Lumina with a rear differential. Did you try Randy's Ring & Pinion, DTS, National Drivetrain?
The Following User Says Thank You to big gear head For This Useful Post:
old yukon (08-25-2012)
Old 08-25-2012, 10:50 AM
old yukon's Avatar
Tried them all no go !
I did 101 searches and the best I cam up with was a Borg warner M78
But every image for a borg warner 78 doesn't match to a Chevrolet Lumina 99.
this is not mine but it come up as a 3.08 Irs m78
this has me stumped.
Old 08-25-2012, 10:59 AM
old yukon's Avatar
Correction borg warner 78 not 76 as the title of the thread says.
Big gear head, you posted something on the borg warner 78 being from Australian rear ends, what would it be doing in a 99 Chevrolet Lumina ?
Old 08-25-2012, 12:21 PM
GM shares some platforms with Holden, their Australian operations. The GTO was a Holden chassis, as is the new SS. Rear drive and AWD is a staple in the Holden lineup.
Is this in a Lumina van? Which engine does it have?
The Following User Says Thank You to lmsport For This Useful Post:
Old 08-25-2012, 12:25 PM
old yukon's Avatar
Thanks for the reply lmsport
no its a sedan
the id tag says engine- LN3 but it looks a lot like the the 3800 series ( L36)
Old 08-25-2012, 03:06 PM
Drivetrain - LS1GTO.com Forums
Go here and see if you can find some information. There are a few guys on there that order Borg Warner parts directly from Australia. That is definately a Borg Warner differential that you have. The '04 to '06 GTO, some 3rd gen Camaros and Trans AMs from '85 to '90 and the G8 all used the Borg Warner differentials.
Old 08-25-2012, 08:40 PM
old yukon's Avatar
You dont call yourself Big Gear Head for nothing. Fount it, i think.
GM 7.75 IRS Rear - 04-06 GTO
its a GM 7.75 IRS Rear - 04-06 GTO
thanks
Old 08-25-2012, 10:03 PM
I rebuilt one of those about a year ago. Randy's had the kit, but it was expensive. They have a reputation for causing problems around 20,000 miles. As I understand it they are actually built by Dana now. Dana suposedly bought Borg Warner in Australia and does the GM differentials there now. They used Koyo bearings in them and they didn't hold up very well. I've still got the GM alignment tool for lining up the GTO rear sub frame when reinstalling the rear end.
Old 08-25-2012, 11:15 PM
old yukon's Avatar
Man now your opening up a new can or worms.
But is seems an important one.
sub frame alignment
discussion
GTO Alignment Process - LS1GTO.com Forums
official procedure
http://www.gto-justice.com/PDF/GTO_C...0Alignment.pdf
here a version of the tool by Pedders
thanks again, your the man !
Hay, anything else I must know before going ahead with the rebuild??
Old 08-25-2012, 11:36 PM
old yukon's Avatar
hears the front tool while we're at it...
Might as well do the who suspension job with all that effort.
Old 08-26-2012, 10:54 AM
old yukon's Avatar
HAY BIG GEAR HEAD
you said you have the Gm tool, right
could you give me the measurements star to star so i can fab up my own jig
that will be a great help
Borg Warner T-10 59 el camino Transmission - Rearend 8 12-30-2007 07:35 PM
borg warner t-5 Q DragBoy4ever Transmission - Rearend 2 04-13-2006 12:41 AM
Borg Warner T-50 Super Chevy Transmission - Rearend 5 03-10-2006 08:05 PM
Borg Warner T-10 i.d. help L72Belair Transmission - Rearend 3 12-29-2005 10:03 AM
borg warner 69at16 Transmission - Rearend 0 03-16-2003 01:02 PM
