Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Borg Warner cracked ears
Old 12-25-2012, 07:56 AM
cranky1's Avatar
cranky1 cranky1 is offline
Just stuck
Most cracked mounting ears I've seen were because some moron tried to pull the trans all the way up flush to the bell housing using the bolts. If things are right, it will mate with the bell housing all the way without any gaps then you tighten the bolts.
