Can you identify this borg warner t-10 1963 I have a borg warner aluminum t10 4 speed transmission.
I need to identify what it came out of and the ratio
Date 9-28-63
T10 L-1
W,G. D1
Numbers on aluminum case stamped in 289
Attached to the 4-speed tranny is a case that is cast
The back yoke attached which could have been added later has the id#r10 f-10 wg div l-1
Also has a tiny piece of metal with a screw at each end.
This tiny piece of metal says *C 14 57*
I think its was a Performance AMC
Thank you
Date 9-28-63
T10 L-1
W,G. D1
Thank you
