Borg Warner Super T-10 information please.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2007, 08:47 PM
I need to know the correct yoke length for a Super T-10 transmission. I sent my Son's T-10 off to get rebuilt awhile back and think I got someone else's yoke back by mistake. From what I remember the yoke I had originally was quite a bit longer than the one I have now and I'm a little worried if I run the short one I might have some bushing problems if it isn't right. I've been browsing the internet trying to figure out what yoke this trans calls for but can't seem to find any info. Ebay is offering numerous yokes that say they fit the TH400, Muncie and T-10 but I really think there is a length difference. Does anyone here know for sure if the T-10 takes a specific length yoke? Are there length differences? Thanks in advance for any info, or links, Bob
Old 03-26-2007, 09:48 PM
onebadmerc's Avatar
I need a bucket of arc sparks
When I put a Ford T10 in my 66 Comet, I used a C4 auto trans yoke. The spline count was correct, but I had to have the yoke shortened to fit the T10 transmission. I have put over 50,000 miles on it and have not had one problem. If the spline count is correct, you should not have any problem with it, if you have to shorten the yoke. Though I had a drive shaft shop put the yoke in a lathe and turn it down. The shop told me it is very easy to mess up a yoke, so I paid them $20 to shorten it.
Old 03-27-2007, 04:26 AM
RippinRon's Avatar
The Super T-10 uses a th400 yoke the muncies and saginaws use a th350 yoke.
Old 03-27-2007, 12:02 PM
larryblack's Avatar
Certified Lead Foot
Your Super T10 uses the T400 yoke for the 6" tail shaft.
The yoke is about 3-1/2" into the tail housing. If your parts guy needs make and model, 1969 camaro 396 with T400.
LQ4 and Borg Warner resto48 Transmission - Rearend 0 06-27-2006 07:06 PM
borg warner t-5 Q DragBoy4ever Transmission - Rearend 2 04-13-2006 12:41 AM
borg warner t5 classic_chevy_guy Transmission - Rearend 2 09-05-2004 07:45 PM
my super t 10 tranny is hard to gear down. Ken. P. Transmission - Rearend 4 08-15-2004 12:42 PM
Borg Warner T-10 fred56 Transmission - Rearend 2 11-02-2002 06:02 PM
