Borg Warner Super T10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2007, 03:47 PM
I have 2 super t 10 trans and don,t know how to decode them. Both have 26 spline inputs and 32 spline outputs. one inch cluster pin and 2.64 1st gear ratios. Trans #1 numbers- main case next to side cover wf2792, top of main case 19L637340, tail housing 13-04-066-905 and side cover 13-04-097-901. Tran #2 numbers-main case next to side cover wm77 2, top of main case 018N53847, tail housing 13-04-066-93 and side cover 13-04-097-901. Any help would be greatly appreciated. thanks, Edwin Martin
Old 06-08-2007, 10:33 PM
65 crusier man
http://www.5speeds.com/casting.html
try this site and i was just there and they list castin numbers
hope it helps
Joe
Ford Borg Warner T10 Codes 65fbstang Transmission - Rearend 0 05-27-2007 10:07 AM
Borg Warner Super T-10 information please.. baddbob Transmission - Rearend 3 03-27-2007 12:02 PM
t10 borg warner application 496hotrod Transmission - Rearend 2 06-16-2006 06:56 PM
borg warner t-10 or super t-10 Jared Transmission - Rearend 2 08-11-2003 10:39 PM
Replacing Borg Warner T10 with Richmond 6 speed beazil Transmission - Rearend 3 05-16-2003 08:59 AM
