Borg Warner Super T10 speedometer gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2012, 07:37 PM
TopDownIroc's Avatar
Just Freakin' Crazy
Last journal entry: My 66 El Camino "Project"
I recently acquired a 1977 BW Super T10 out of either a Camaro or Firebird. My question is about the speedometer gearing. I have a 66 El Camino with a factory 3.36 rear end gear in it. Can the speedo drive gears be changed without breaking into the transmission ie. externally, or will it require an internal and external gear change like an automatic? I'm not sure what ratios the mid 70s F cars had from the factory so I'm not sure how much of a change is going to be required to calibrate my old school mechanical speedo. Any help will be appreciated. Thanks!
Old 03-14-2012, 08:47 PM
BOBCRMAN@aol.com's Avatar
Tailshaft will have to come off to change the drive gear. MANY different combos of drive and driven gears. I use a company called Spec-Mo. for ratio/gear colors.
Old 03-14-2012, 08:58 PM
Just Freakin' Crazy
Thanks for the information. I thought I was correct in this, but an old school guy told me different. Looks like the perfect excuse to buy a GPS speedo in case I ever want to change gear ratios. Thanks!
Borg Warner T-10 and Super T-10 Catalogs AutoGear Transmission - Rearend 13 12-06-2011 11:06 AM
Borg Warner Super T10 edwinmartin1 Transmission - Rearend 1 06-08-2007 10:33 PM
Question regarding Borg Warner Super T 10............. Trans Am Tony Transmission - Rearend 1 04-30-2007 06:34 PM
Borg Warner Super T-10 information please.. baddbob Transmission - Rearend 3 03-27-2007 12:02 PM
borg warner t-10 or super t-10 Jared Transmission - Rearend 2 08-11-2003 10:39 PM
