borg-warner T 10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2003, 01:46 PM
Post borg-warner T 10
I've got a T-10 in a 55 Belair behind a 55o hp small block topped with a hurst compitition plus shifter. At the end of the season last year with no warning it started jumping out of 1st. gear. I have always had a bit of a problem with it jumping out of 3rd gear under a lot of tourqe. I have adjusted the linkage and now it won't engage 1st or 3rd. The unit is only 2 years old with less than 3000 miles on it. Is it time to rebuild or have I over looked something.
Old 02-23-2003, 05:01 PM
BOBCRMAN@aol.com's Avatar
Post
double check your shifter adjustment, sounds like its not correct.
