Borg Warner T-10 to Chevy 235 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2012, 08:03 AM
I am working on a 1954 Chevy 235 6 cyl and want to do away with the enclosed driveline. Can I use a Borg Warner T-10, aluminum 4 speed, and if so what do I need to adapt it? ... Thank You
Old 01-15-2012, 09:43 AM
Crosley's Avatar
Wiki Edits: 1659
I bolted up a Saginaw directly onto a 1955 chev 235 truck engine bell housing. Engine was in a 1950 chev 1/2 ton truck. I used a 1967 chev 1/2 ton differential with 6 lug wheels.
Requires a special shifter location mount in a truck... a car should be easier to mount the shifter.
Are you familar with Patrick Dykes of Patricks Antique Cars n Trucks in Casa Grande AZ ? He builds many parts for these old Chev engines
Old 01-15-2012, 11:08 AM
Thank You ... I am familiar with the site and I will further check him out.
borg warner t10 dean652 Transmission - Rearend 3 08-24-2010 02:59 PM
Need Borg Warner help Not Shifty Transmission - Rearend 2 09-30-2009 07:16 AM
Borg Warner t-10 I. D. hdzeez Transmission - Rearend 2 09-25-2009 08:03 PM
Borg Warner T56 in a 40 chevy black knight Transmission - Rearend 0 05-20-2006 03:34 PM
Borg Warner T-50 Super Chevy Transmission - Rearend 5 03-10-2006 08:05 PM
