Borg Warner T-10 i.d. help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2005, 06:22 PM
L72Belair's Avatar
Need help trying to identify this tranny, it is a t-10, cast iron case & tail housing,alum. mid plate, there is a tag on the side cover, B-W, AS3-T10W.#'s on side of case 13-04-065-902.
letters on case, W.G.DIV. then a backwards "D"-1, coarse spline input shaft w/2 rings. 7/8" counter shaft.The tail housing has WG DIV, F 2172, T10K-7 on it, and has 2 mounting bosses for tranny mounts,(never seen that before) and multiple bolt patterns for a shifter, was wondering if this was an over the counter replacement trans. or came in a car? it's a chevy bolt pattern. Can't seem to find much info on t-10's. If it was a Muncie, probably could have found out who built it, on what line, and his kid's birthdays any help would be great! Thanks Pat.
Old 12-28-2005, 08:18 PM
http://fiedlerh.home.att.net/BW.htm
Looks like it was made June 21, 1977 on the 2nd shift. Check it though I could be wrong, I did it from the memory of your posted numbers so...I also couldn't find the kid's birthday.
Old 12-28-2005, 08:20 PM
http://fiedlerh.home.att.net/images/ST10man.pdf
If you want to see what the inside looks like.
Old 12-29-2005, 10:03 AM
larryblack's Avatar
Certified Lead Foot
Usually T10s with iron case and aluminum tail shaft were second design SUPER T10. If so, the case is a high nickel content and the gears are a mite stronger too.
Some of the 77 to 79 Z-28's had all aluminum T10s.
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
borg warner t5 classic_chevy_guy Transmission - Rearend 2 09-05-2004 07:45 PM
Borg Warner 4 speed I.D. Dave Y. Transmission - Rearend 1 06-18-2003 10:25 AM
Borg Warner T 56 Silver Transmission - Rearend 1 05-13-2003 09:22 AM
Borg Warner T-10 fred56 Transmission - Rearend 2 11-02-2002 06:02 PM
