Borg Warner T-10 and Super T-10 Catalogs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2010, 02:12 PM
Borg Warner Late (POST 1974) T-10 and ST-10 Assembly Manual and service info.
This has Auto Gear-drawn parts diagrams, and assembly info and part numbers for you T10/ST10 guys.
Used with permission from A.G.E
Old 11-08-2010, 05:26 AM
4speed's Avatar
Ohio Firebird Member
Last journal entry: 77 TransAm W72
between E3 and E4 (2nd&3rd gear) there is a shim of some kind.
I need that. mine doesnt have one.
I have the super T-10 BW in my trans am
does any one have this part or know were to get it.
Old 11-08-2010, 07:05 AM
Thanks for looking at our stuff. What year Firebird do you have; or, more correctly, what year is the transmission. Later T10s have a thrust flange on one of the gears, so a shim isn't used.
Nathan Huxtable
Old 11-08-2010, 09:05 AM
4speed's Avatar
I'll get back to you on the info. I'm thinking 1976 or 78 I have 3 of them.
when its in gear in 2nd and I let off the gas the trans grinds(slips)
I was told there is to much play between 2nd and 3rd gear.
I can email pics to ya of what I have.
Old 11-08-2010, 09:45 AM
When you're ready to send pics, post them here for the benefit of people who might have the same issue
Old 11-08-2010, 11:50 AM
4speed's Avatar
here is the pics looks like a 76 or 78 date on it
ID:	49782   Click image for larger version
ID:	49783   Click image for larger version
ID:	49784   Click image for larger version
Old 11-09-2010, 06:13 PM
4speed's Avatar
any help?
Old 11-10-2010, 07:22 AM
Sorry about the delay.
If you look really close in the first picture, thegear to the left has a thrust flange you can barely see. So no this particular trans doesn't have a shim there. How bad does it slip?
Nate
Old 11-10-2010, 08:26 AM
4speed's Avatar
bad!! but not in gear when gasing it. just slips when you take off the gas ,in gear. and cant down shift.
Old 11-10-2010, 09:30 AM
Coolball's Avatar
Last journal entry: First Entry 82' Camaro Z28 Project
Thank you for posting that. It will come in handy at some point in my 82 Camaro build which has the Super T10.
Old 11-12-2010, 08:49 AM
you need to completely disassemble the trans and inspect the gears. My suspicion is it just needs an overhaul kit with new "competition" synchronizer rings. However if the gears look worn, theyll need to be replaced. "roll" check them against the cluster gear and look for uneven-ness in the way they mesh.
OH kits are all over the map, price-wise. A quality one will be over 100 bucks and some do or DO NOT include the countershaft, so check yours too and see if it needs replacing. Mine come with all the seals, SKF bearings, bushings, 4 synchro rings, springs n struts, o-rings and a gasket set. Price is $137. Contact me via PM if you want.
Old 11-12-2010, 08:58 AM
4speed's Avatar
this is a new kit. paid 140.00 for it. it might have 30mi on it.
and paid some jack wagon to put it together.
Old 12-05-2011, 06:32 PM
I be a ST-10 guy...Thank You!
I have just completed a transmission swap; installing a 1982 Camaro Super T-10 transmission into my 1986 Corvette (replacing the DNE 4+3 trans) using a custom made adapter, signal generator, and [lenghtened] driveshaft.
The Camaro Super T-10 has the 26 spline input and 27 spline output shafts.
I have a 2nd 1982 Camaro Super T-10 transmission and the gearbox (OD assembly detached) from a 1985 Corvette DNE 4+3. I have been told that the complete gearset will swap into the Camaro Super T-10 case.
What all would I need to complete this gearset swap??? I'm guessing a new mainshaft...Plus the usual seals, bushing, gaskets, etc...
Thank You!
Old 12-06-2011, 11:06 AM
Greetings;
At first blush; Mainshaft, idler gear and midplate. Take a look at the yellow catalog posted earlier and compare that with a DNE list. I do not have a diagram for the 4+3. There used to be a guy in FL who specialized in them but he finally walked away from it.
We'll help you any way you can, but split this into a new thread please
Borg Warner Super T10 edwinmartin1 Transmission - Rearend 1 06-08-2007 10:33 PM
Super T 10 locking in 2nd gear...... Trans Am Tony Transmission - Rearend 2 05-30-2007 10:49 PM
Question regarding Borg Warner Super T 10............. Trans Am Tony Transmission - Rearend 1 04-30-2007 06:34 PM
Super T 10 71 c-10 Transmission - Rearend 2 03-16-2007 05:11 PM
my super t 10 tranny is hard to gear down. Ken. P. Transmission - Rearend 4 08-15-2004 12:42 PM
