borg warner t-5 Q - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2006, 02:51 PM
borg warner t-5 Q
how much h.p. and torque can a borg warner t-5 handle
Old 04-10-2006, 03:39 PM
From what I've seen, about 6 strong cylinders worth. I know of several T-5 trannys that failed behind stock to mildly built V8s. That being said, there are at least 2 different levels of T-5 trannies. These may have been the weaklings. Check out this site for some great info: http://www.moderndriveline.com/Techn...t5_history.htm
Old 04-13-2006, 12:41 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
There is some good information in the knowledge base. If you have the tag ID number you can go to a site and get the full data about any T5 trans.
The good T5s live behind some pretty wild engines unless the slicks and clutches get too sticky and the driver is a clutch-Klutz.
There is NO substitute for a "PRO-5.0" brand shifter. PERIOD.
Please use sythentic ATF only. I have had wonderful experience with Mobil 1.
I need a Borg Warner or Tremec classic_chevy_guy Transmission - Rearend 1 09-16-2004 10:00 AM
borg warner t5 classic_chevy_guy Transmission - Rearend 2 09-05-2004 07:45 PM
Borg warner 5 speed Scuzzy Transmission - Rearend 5 10-17-2003 01:01 AM
Borg Warner Identification cruiserlck Transmission - Rearend 1 02-16-2003 10:45 AM
Borg Warner T-10 fred56 Transmission - Rearend 2 11-02-2002 06:02 PM
