borg warner t10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2010, 07:22 AM
borg warner t10
I have a 61' T-10 4 speed, new Hurst shifter. When I take the car out of reverse it seems jammed, and sometimes seems locked between gears. Any help?
Old 08-24-2010, 09:44 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
first thing is welcome to the board and if you post your question in the trans forum someone will see it and try to help you..
Sam
Old 08-24-2010, 11:38 AM
poncho62's Avatar
Wiki Edits: 5
sounds like your shifter needs aligning....or rebuilding
Old 08-24-2010, 02:59 PM
Buy a 'pit pack' for like 10bucks and replace those lousy plastic bushings in the new shifter with steel ones; and use a drillbit as an alignment pin and align your shifter properly. That should fix your problem.
Transmission Issues with a Borg Warner Super T10 Camaro83 Transmission - Rearend 9 09-08-2010 06:31 PM
Borg Warner T10 question Tomlowe523 Transmission - Rearend 4 08-01-2009 10:19 PM
Ford Borg Warner T10 Codes 65fbstang Transmission - Rearend 0 05-27-2007 10:07 AM
t10 borg warner application 496hotrod Transmission - Rearend 2 06-16-2006 06:56 PM
Replacing Borg Warner T10 with Richmond 6 speed beazil Transmission - Rearend 3 05-16-2003 08:59 AM
