Borg Warner t56. Can you change shifter position?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2013, 04:51 AM
Hi,
I am looking at a Borg Warner t56. I need to move the shifter forward to where the inspection cover is. The application I want it in is a 55 2nd series chev pickup and if its not moved, the shifter will be under the bench.
I know that a shifter relocation kit is available for the tremac t56 but was keen to find out if there is one for the Borg Warner.
Cheers
Old 07-30-2013, 07:20 AM
Borg Warner sold the majority of its typical manual transmissions off to Tremec out of Mexico. The T56, T5, T45 etc were BW designs and were sold to Tremec. Assuming theres no difference in the master shift rail, your relocation kit will work. Contact an "elite" dealer with the tag number of your transmission (1386-xxx for example if its a Warner unit; TUETxxxx for example if its a Tremec). They should be able to tell you if the kit fits that specific application.
I'd recommend D&D Performance out of Michigan. They've been around a long time and answer their emails promptly.
The Following User Says Thank You to AutoGear For This Useful Post:
OLNOLAN (07-31-2013)
Old 07-30-2013, 03:47 PM
OLNOLAN's Avatar
The Gear Box
Well, I was on go to order a kit from this place and it appears they are on backorder from their supplier.
T56 6 Speed Transmission Parts & Rebuild Kits
Nate, do you know anything good or bad about these folks?
Nolan
Old 07-31-2013, 06:49 AM
Sure do; Kevin and Judy were here in Syracuse a few months ago. They're one of my best customers. Kevin is a great builder, very knowledgeable and their prices are usually some of the best out there. I didn't suggest him because they've been on vacation and I didn't think he was tending emails.
If you can post or PM me the part number, I can dig around and see if I can find someone. However, Tremec's support of the T56 is falling off rapidly. It started life in 1993 and ended in 2002. They're only on the hook for 10yrs after that. I imagine the relocation kits are something they produce once a year when enough get back ordered.
Old 07-31-2013, 08:38 AM
OLNOLAN's Avatar
Part Number
Nate, I don't see a part number in the Gear Box link. It just says T56 front shift conversion kit and a footnote to let them know what specific transmission.
I need the kit for my '57 project, I'm trying to get it moving along again and the kit is a first move to getting the engine/transmission mounted. I've already built the engine mounts and transmission crossmember, but had to put the project on hold a while back.
On the subject of Tremec discontinuing support on the B/W t56, I have two '97 B/W t56 transmissions, one for the project truck and another in my street/strip '97 Camaro SS. My Camaro transmission is getting a bit sloppy and noisy but hasn't failed yet. I'm not worried about the one for the truck as its only a 23,000 mile unit. My friend and transmission builder suggested replacing the sloppy one with a brand new Tremec vs. attempting a rebuild because the cost of the new parts & labor would likely exceed the cost of the replacement. So I've decided to just run it until it breaks.
If Kevin and Judy read this, they will know there are at least two people interested in buying a kit, so tell them to get back to work! I don't see a B/W t56 shifter relocation kit on the D&D site.
Thanks for being a great asset when it comes to manual transmission advise on this forum. Nolan
Old 07-31-2013, 09:24 AM
Front shift on a T56 is not something a weekend mechanic should attempt; you have to disassemble the gearbox and modify (or change) the shift rail I believe. Its not a bolt on deal like the 6060/Magnum.
Thats definitely a custom kit and looks very nice. Let me do some digging.
Thanks for the appreciation! Im here as a gearhead and not a salesman, anything I can do to keep from seeing another auto stuffed in a car.
RPM Transmissions and Texas Drivetrain Performance have exchange/core programs, might be worth a look. Both Guffey (RPM) and Jason (TDP) build great transmissions.
borg warner, relolcation, shifter, t56
Need Shifter for Borg Warner T-10 65fstbk Transmission - Rearend 3 04-09-2007 10:33 AM
Borg Warner T56 in a 40 chevy black knight Transmission - Rearend 0 05-20-2006 03:34 PM
Borg-Warner T-10 shifter ? Lusty1 Transmission - Rearend 1 01-05-2003 05:11 PM
blue print for t56 borg warner 50chev Transmission - Rearend 0 11-18-2002 04:54 PM
blue print for t56 borg warner,flywheel and clutch 50chev Engine 0 11-18-2002 03:10 PM
