borg warner trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2009, 09:55 AM
steve
borg warner trans
hello, I have a borg warner 4 speed I'm going to put in my recently converted to chevy amx, and have to rebuild it, the numbers on the case are 13-04-066-903, it's aluminum case and has a 32 spine output shaft, can anyone tell me what model it is?, any info about it would be great.
Old 02-28-2009, 10:15 AM
steve
borg warner 4spd
hey still getting used to where to post in here, I have a borg warner with numbers 13-04-066-903 on the case, it's aluminum with a 32 spine output shaft, can anyone tell me what model it is and if they were any good, I have to rebuild it before installing, also have a cast case unit, the only numbers I can find on it are.... 9079 GM 3925656 with 27 spline output shaft, there both side loaders, any ideas, thoughts on which one is better to build for my project ?
Old 02-28-2009, 10:33 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
your numbers come back as a saginaw trans. cole
Old 02-28-2009, 10:35 AM
steve
your talking about the GM trans ?
Old 02-28-2009, 10:46 AM
CrashFarmer2's Avatar
Freezing in arctic Iowa
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
Hello and welcome! This question would get more responses in the Transmission - Rearend section.
Old 02-28-2009, 10:49 AM
eloc431962's Avatar
Wiki Edits: 37
Its a super t10.maybe this will help.borg warner t-10 or super t-10 .cole
Old 02-28-2009, 11:00 AM
steve
ok, it's aluminum case so it's a T-10 ?, are these any good?, thanks by the way
Old 02-28-2009, 11:21 AM
eloc431962's Avatar
Wiki Edits: 37
I have never owned one. but people i have talked to in the past has told me they were a good trans. cole
Old 02-28-2009, 11:30 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
thwrench;
i merged your threads on this manual transmittin together so easier reading and follow ups.
good luck , have fun
Old 03-01-2009, 04:29 AM
junior stocker's Avatar
BW trans
Sounds like a Super T-10 to me, but the numbers don't match up. If it has 26 count input splines, and 32 count output splines, then it's a Super T-10, and by the numbers, probably a factory installed unit. Summit Racing lists 5 different Super T-10 transmissions, all with different gear ratios. There's even a Super T-10 "PLUS" that's a road racing trans. Good trans? I have a Super T-10, 2.64 first gear, going in my 56' Chevrolet Sedan Delivery with a .040 over 327, 340 HP short block, 461 X casting ported/polished heads (Please don't run down the camel humps, and suggest Vortecs; especially with the factory small dome pistons in the motor), old style Edelbrock 180 degree high rise, 750 Holley, and all aftermarket valve train, 11" clutch, 4.88 posi in an old 57 Olds rear end. O.K., so I'm old school! My trans will be fine, and so will yours.
Borg Warner 4- Speed TRans Marks Garage Transmission - Rearend 2 06-04-2008 12:29 AM
Replacement T5 Borg Warner gears x711 Transmission - Rearend 1 12-16-2006 10:26 PM
LQ4 and Borg Warner resto48 Transmission - Rearend 0 06-27-2006 08:06 PM
borg warner t5 classic_chevy_guy Transmission - Rearend 2 09-05-2004 08:45 PM
borg warner or t 14?? 53fordguy Transmission - Rearend 1 04-12-2004 03:53 AM
