Borg Warner Trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2010, 03:11 AM
Borg Warner Trans
I'm wandering if anyone can give me some ideas of how to get my borg warner 4 speed from my 78 camaro looking like new again? Just wandering the easiest and best way to clean up the housing and get it to look factory. Thanks really appreciate any input from someone that has done this at some point.
Old 09-18-2010, 03:42 AM
ericnova72's Avatar
More for Less Racer
Disassemble, or very tightly cap all openings like input shaft, output shaft and vent - and beadblast it. You could also try the acid wash truckers use for cleaning bare aluminum wheels, but I don't think it will give the "as new" look like beadblasting will. Depends on if you just want it clean and stain free, or of you want the same look it had when brand new for a #'s matching restoration.
Old 09-18-2010, 05:33 AM
sqzbox's Avatar
My pipes are my music
The aluminum brightner Eric is talking about will do the job if you use it full strength but, you will have to remove all dirt and road "tar" off the case.
Is is also caustic so you don't want to get any on your skin or eyes. You can wash it off with water and dilute it down from full strength also. It costs about 30 bucks a gallon from a semi truck parts store such as kenworth truck supply and sales centers. I used it on my performer intake I bought used and it made it look new again. If you don't feel comfortable using acid or don't have an area to do the job, bead blasting might be the way to go.
Old 09-18-2010, 07:49 PM
Ok thanks i will check into both options and see what i can find here. Not sure i can get the cleaner stuff where i am but i will look into it. Thanks for the help.
Borg Warner ID Help 1963 4 Speed ID#and date here in2classx Transmission - Rearend 1 09-26-2008 08:19 PM
Borg Warner 4- Speed TRans Marks Garage Transmission - Rearend 2 06-04-2008 12:29 AM
t10 borg warner application 496hotrod Transmission - Rearend 2 06-16-2006 07:56 PM
borg warner t-5 Q DragBoy4ever Transmission - Rearend 2 04-13-2006 01:41 AM
Borg warner 5 speed Scuzzy Transmission - Rearend 5 10-17-2003 02:01 AM
