Borg Warner Transmission and Ford 8.8 inch rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2011, 09:33 AM
Hi,
I have a used Borg Warner T5 transmission with the follwwing id numbers on the casing. R3 Borg Warner 1352066919 - F6ZR6394AA
Can you tell me what year this is and if it is a world or non world transmission.
I also run an 8.8 inch Ford rear end and am looking for the housing torque spec's for it.
Thanks
Mike La Rocque
Old 03-29-2011, 10:40 AM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
T5 Identification info
Originally Posted by 5speeds.com
Casting numbers on the side of the main case or extension housing CANNOT help you ID a transmission simply because the same case is used in a variety of models. Some pictures will show you ID tips. There is also a TAG ID program. The TAG id program requires the stamped number off of the tin METAL TAG bolted to the tail housing. No other numbers on the case, tail or cover are needed or will tell you anything.
Need help identifying a Borg Warner T-10 transmission Ray63 Transmission - Rearend 4 03-21-2016 10:14 AM
Transmission Issues with a Borg Warner Super T10 Camaro83 Transmission - Rearend 9 09-08-2010 07:31 PM
borg warner transmission rdutra Transmission - Rearend 0 09-09-2009 10:17 AM
Need help to Id 4sp borg warner transmission jayday Transmission - Rearend 6 08-25-2009 12:20 AM
Need help identifying a Borg Warner T-10 transmission Federico Transmission - Rearend 3 08-04-2008 08:39 PM
