I would use the splined or double D shaft and joints and then you won't have to do either. Just install the joints and lock with the set screw.
Andy |
I just did mine with borgesons splined and double D shaft. Expensive , but it is going on the street . And I can take it apart if need be. Once you are sure everything works OK mark the set screw and drill a dimple in the shaft for it to sit and will never move.
I filed the ends of you 3/4th round steering shaft into a DD shape to fit in the borgeson u-joind. I just bought a u joint from them what a B***, cost me 100 to it home. And thats just for a plain steel shaft. Its going to rust later. I have heard that the astro van u joints work to but who knows how safe Junkyard parts are. Ya don't pin em or weld them just used DD and index screw to secure them Last edited by 31chevy; 03-02-2009 at 10:10 PM. |
| Heim Joints, Tie Rod Ends | Jsup | Suspension - Brakes - Steering | 20 | 03-01-2009 09:00 PM |
| I bought the wrong borgeson joints | Lil John | Suspension - Brakes - Steering | 2 | 02-26-2009 08:10 AM |
| Ball Joints....not a hot rod but.... | screamin340 | Suspension - Brakes - Steering | 7 | 08-05-2005 03:51 PM |
| Front end U joints | Trav | Transmission - Rearend | 2 | 10-06-2003 06:52 PM |
| Ball Joints Question!!! | bg | Suspension - Brakes - Steering | 2 | 03-31-2003 06:26 PM |
