Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Borgwarner T5 clutch questions
Old 02-15-2013, 04:29 PM
logan1 logan1 is offline
Originally Posted by OneMoreTime View Post
What you have done is very common in the engine swap world..Any of the guys who do custom clutched ca handle this. I would recommend an SFI pressure plate and clutch for you application and you do have a scattershield or sfi bellhousing I hope..
thanx for the info but do i need to upgrade a pressure plate or can i run the current pressure plate with an upgraded clutch?
Also no i do not have a Scattershield sfi bellhousing yet. Just running the stock T5 bellhousing.
