Bosch Relay Contacts - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2009, 06:55 PM
I have wired my torque converter lockup using a relay to pass the 12v current to the lockup solenoid. Converter worked before going to the relay circuit.
Now the converter never locks up. Does it make any difference whether you interchange coil contacts 86 and 85. Most diagrams show power coming to contact 86 and 85 used as a ground.
I reversed these and hooked power to 85 and grounded 86. Would this prevent the coil from activating?
John
Old 09-11-2009, 07:24 PM
Not sure about your particular relay, but some have a diode connected across the coil to eliminate the inductive "kick" that the coil can produce at the moment it is de-energized. If that is the case with yours, then proper polarity is critical. If it is connected such that the diode conducts when the coil is energized, then you have essentially a short across the relay coil that would prevent the relay from energizing. I'm guessing that if you reverse the coil connections, your problem will be corrected, if you didn't fry the diode. Usually when a diode fails, they short out. If that happened, replace the relay.
Old 09-11-2009, 09:27 PM
I am using a relay because I have incorporated a RPM switch into the control circuit so that lockup only occurs above a specified engine RPM.
I tested the RPM switch and it doesn't seem to be completing its circuit no matter how high I rev the engine. That must be my problem.
I have a second relay from same manufacturer and I checked it by applying voltage both ways across the 85 and 86 contacts and it provides continuity between 30 and 87 either way. Have not pulled the relay I used from under the dash to check it yet, the RPM switch appears to be the problem.
John
Old 09-12-2009, 08:22 AM
302 Z28's Avatar
Here are a few wiring diagrams.
With tow application
Without tow application
Vince
Old 09-28-2009, 09:29 PM
ema ema is offline
New Member
Thank you for posting these infos here. I had a problem on understanding some stuffs with this bosch relay . Good thing I realized it here.
Old 09-29-2009, 07:47 AM
Update -- the problem was a bad crimp connection between the RPM switch and the relay. TC lockup works nicely now.
John
Old 09-29-2009, 08:57 AM
302 Z28's Avatar
Glad you got it fixed.
Vince
Please help! Radiator fan not working! billsbird Electrical 7 09-01-2007 03:49 AM
Can I build this wireless led brake light cheap? cboy Electrical 11 07-07-2007 12:16 AM
93 Plymouth Acclaim fuel pump relay 78 monte Electrical 14 04-19-2007 04:09 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
Power Seats MI2600 Electrical 4 10-06-2005 05:55 AM
