Both headlight inop - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2006, 05:49 PM
Both headlight inop
I was just driving my car and found out that both of the headlights are not working, It is a 1970 nova. Checked for power at both headlights and there was no power. When pulling the headlight switch the fog lights come on and so does the dashlights,sidemarker light, rear taillights and tach.light. I know that it is not the headlight it self because both of them went out at the same time, is there a relay that could cause the lights to go out. Any help would be appreciated.
Old 01-15-2006, 05:56 PM
mike, check your fuse panel for blown headlamp fuse, also I've had the dimmer switch [hi/low beams] go bad and give same result.
Old 01-15-2006, 05:57 PM
poncho62's Avatar
Wiki Edits: 5
Check the dimmer switch....................there are no headlight fuses. There is a bi.metalic breaker in the headlight switch that resets itself.
Ontario Rodders
Old 01-15-2006, 06:01 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Check the Head lamp switch too
I'm 79 ford 's went bad & I didn't figure it out until one night they started flashing on & off .
Well people got out of the was though
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 01-15-2006, 09:01 PM
both headlight inop
I just wanted to thank you, it was the dimmer switch just went to autozone and bought one for 4 dollars bolted it on and now the headlights work.
Headlight burned or what? 69ChevelleAddict Electrical 3 07-18-2005 07:00 PM
38 headlight lens/cover 38 special General Rodding Tech 7 07-29-2004 12:54 AM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 08:31 PM
Headlight Bezels & Visors horvath Body - Exterior 2 05-16-2003 06:14 PM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 07:36 AM
