Bottom end?
This is that little jewel i was talking about in the other thread:
http://www.youtube.com/watch?v=ddA1MgLex2Q When they say bottom end are they talking about the main caps or the reciprocating assembly? Incidentally, i don't think 4 bolt mains can be added to this block----229 is a 305 minus 2 cylinders. But not sure; would have to double check if possible. Also as far as mods to the block, what would this entail? i haven't called them yet, because i'm not at that stage yet. Last edited by against all odds; 03-20-2012 at 08:08 PM. |
I have no doubt they added splayed caps to the stock 2-bolt block. They used an even fire crank- that alone puts the cost up there pretty good. Add the massive amount of work the heads would need, and a custom solid roller valve train... I'd imagine a SBC V8 could have been built for half the cost that made a lot more power.
Impressive power, just the same. Can't imagine why his customer didn't want to use a 4.3 L engine (if it had to be a V6 Chevy 90 degree NA engine) to build from, though. |
SBC 4 bolt main blocks are only 4 bolt on the middle three m ains. Lose one main on a V6 and you should be able to do 4 bolt on the middle two mains.
When they refer to bottom end, they maen all of the crank, rotating assembly, etc. Not just one or the other. Top end is heads, cam, lifters, etc. |
| 383 bottom end (pic) | v8hed | Engine | 33 | 02-12-2011 11:27 AM |
| 350 bottom end | JohnyR17 | Engine | 4 | 10-30-2006 10:38 AM |
| Goo on the bottom? | 69ChevelleAddict | Body - Exterior | 6 | 06-12-2005 06:11 PM |
| What bottom end to use | NovaSS350 | Engine | 0 | 06-13-2004 02:50 PM |
| What is bottom end? | Rubberman2003 | Engine | 3 | 07-13-2003 01:33 PM |
