bought a bad engine....what to do - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2010, 08:09 PM
So i just bought a used 383 for $700. Guy said he just put new gaskets in and everything looked good.....my *****. I went to do a head swap and found out that the wrist pin on one rod had pushed into the cylinder, and is way beyond boring out. Took the rest apart and the everything looked reusable except the pistons and the block obviously. Money is really tight, what are my best options. Can i use a 400 block with pistons for 5.7 rods, and super oversized main bearings if there is such a thing? I dont know im just to bummed to think right now. Whats your suggestions
Old 06-21-2010, 09:18 PM
Get you money back.
Old 06-21-2010, 09:28 PM
Get your money back
the block is no good so the court WILL be in your favor if he wants to go that far.
Old 06-21-2010, 09:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Another 350 4-bolt block would be a good way to go. Or you could see about sleeving that cylinder.
If not, there are spacers or thick bearings for using the 350 crank's 2.45" journal in a 2.65" 400 journal block, this nets you 377 ci w/a standard bore, about 382 ci @ 0.030" over.
Cleveite P/N for the bearings is TM77-MS-1564-P, shown on pp99 HERE .
Spacers are available from several parts suppliers, THESE are from Speedway.
You'll also need to align hone.
Old 06-21-2010, 09:47 PM
Duster 340
Sleeve it
You need to have the block cleaned anyway, when you have new cam bearings and freeze out plugs installed, have a sleeve put in the one cylinder, no biggie there.
Old 06-21-2010, 10:12 PM
sickolds's Avatar
sickolds
i hate mother ****ers that sell damaged things and say (oh its runs good oh i just had some work done to it ) bull **** ******* why cant u just tell me whats really wrong so i can fix it or rebuild it instead of me waisting my money and time i just bought a trans th350 and the ******* i bought it from said he had it in his truck and it ran good bull when i opened it up the case was shot out everything in it was trash
Old 06-22-2010, 10:15 AM
SS66chevelle's Avatar
HR VIOLATION
The seller misrepresented the goods and I believe you would have legal recourse although the legal fees may eat away at your $700 very quickly.. I would simply approach the seller in a non-confrontational but very direct tone and explain what you found and request a full refund. If you go in hot and heavy, you won't get anything but a defensive uncooperative response from him. (dont accuse him of knowing ahead of time, he will never admit it)
If you dont get a refund it sounds like most of your parts would be reusable on a fresh block.. In that case I would suggest a 350 block since there are some differences between the 350 and 400 blocks (crank??) and I don't think everything is interchangable between the two.. I'm sure someone on here can tell you everything there is to know about those differences though!!
Old 06-22-2010, 10:34 AM
boatbob2
Sorry Sellers.....
Hi,that reminds me of the time i bought 5 gallons of Chris Craft Gel Coat, custom color matched,$200.00 + $72.00 shipping,when it arrived,and i opened it,the gel coat had a red tinge to it,when i stirred it,i found 5 greasy red shop towels in it,i sent it back,they sent it back to me. so,i waited almost a year.and went to visit them on saturday nite,i EPOXIED all their door ,and garage door locks solid,then,threw the 5 gallons of gel coat (opened) thru their window,uncatalyzed (of course) i believe in direct action,do me,i will do you.and what comes around,goes around. it probably cost them $1000 to clean the mess up,(if they ever did).
Old 06-23-2010, 01:00 PM
I went back to the guy and told him the situation in a non confrontational way. He gave me $500 and let me keep the engine. There is an older man who is going give me a 400 block thats been bored .030 over and some heads that have had 2.02 in. and 1.6 ex. valves installed So if i did all my homework right if i use the 383 crank, main bearing spacers, 400 pistons designed for 5.7 rods, and the damper and flexplate from the 383, it should work in the 400 block. Not to mention the block and rods dont need to be ground to fit the crank as it would with a 350 block. Now i dont want to get ahead of myself but i'll tell you my setup so if anyone is really eager they could help me pick out a cam. 78 camaro, 3400 lbs, 3.42 gears, 26in tall et streets, manual (hoping to get a th350...Im not afraid of a 3000 stall either), 750 holley, 10:1 compression, airgap intake, headers, 3 dual exhaust with cutouts, street/strip, shifting at 6200 rpm, looking for a solid flat tappet. Hope someone can answer all these questions lol. thanks again guys
Old 06-23-2010, 06:57 PM
sickolds's Avatar
sickolds
i think it needs to be balanced again if the piston is no good
Old 06-30-2012, 05:29 PM
Duster 340
Sounds as if you are on your way. If you want to balance everything, do it yourself. Buy you a small scale and weigh each piece, find which one is the lightest, match the others too it. If you need to know how to balance, there are many articles out there that will show and tell you how.
Old 06-30-2012, 08:01 PM
Banned
That is NOT going to do you any good when trying to balance a crank...
Old 06-30-2012, 10:41 PM
327NUT's Avatar
This post is 2 yrs old.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 05:07 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
bought a new engine superrican Engine 2 03-15-2006 09:33 PM
Cold weather's back, so is bad engine performance...help! MopaRV Engine 23 11-07-2003 10:02 AM
