Bought a TCI T-400 but all parts not included - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2013, 02:04 PM
Turbo-CBX's Avatar
Ugly, Filthy, Discusting!
Ordered a TCI TH400 Streetfighter and discovered the th400 Speedometer Drive/Driven Gears and Housing are not included. Kind of a cheap way to sell premier transmissions!
Couple of related questions:
First, I have a worn out 700R4. Will the speedometer gears and housing fit the TH400?
Second, anyone know why TCI doesn't include the speedometer hardware when selling their TH400?
Thanks.
Old 06-16-2013, 02:07 PM
Banned
Thanks.
did you ask for it.
or they to guess what rear gears you are running and the tire dia.?
mine came with one. but I told them it was 4:11 gears and 26" tire.
are you running a speedo cable or an electric one.
they are not mind readers
Old 06-16-2013, 02:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Speed-O parts are extra usually , only a gear is included on the out put shaft.
Speed-O housing from a T-700 trans will not fit the T-400. Hole in T-400 is smaller than the T-700
Turbo-CBX's Avatar
Just the facts
I have an electric speedo that is driven off the mechanical speedo output. No problem reprogramming for correct speed.
The TH400 product documentation stated,
"Notes:These transmissions are shipped without the speedometer driven gear or itís housing. If replacing the same model of transmission, these may be re-used from existing. If not, they must be purchased separately."
TCI Super Streetfighter T-400 spec sheet? TWINRAY Transmission - Rearend 8 07-06-2011 08:59 AM
I bought a parts car jessicafd Hotrodders' Lounge 6 05-13-2011 06:48 PM
TCI turbo 400 cameano Transmission - Rearend 3 04-23-2006 07:34 PM
Can I return this car I bought..all the parts arn't here?? tm454 Hotrodders' Lounge 18 02-05-2006 05:59 PM
Bought the parts donor truck today... DesertPanel Hotrodders' Lounge 0 11-02-2003 08:12 PM
