Bow in convertible top bow? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2013, 08:04 AM
I took my Gran Sport on the first long drive last week going a hundred miles away down a long freeway at 75 mph plus and noticed a wind noise. I was blown away to see light between the header and the windshield frame! I could pull down on it and close it up stopping the wind and the light.
It wont' tighten up anymore on the sides, the clamps are VERY tight, too tight I think if anything. Could this be causing it or do I need to block up each side on the windshield and pull down in the middle bending the header down maybe?
Old 11-18-2013, 11:06 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I think bending the header down may solve the problem..Those can get a bit warped or may have been bent a bit in storage..who knows..
Sam
Old 11-18-2013, 01:08 PM
Thanks, Brian
Old 11-18-2013, 08:12 PM
DanTwoLakes's Avatar
Wiki Edits: 22
That's pretty much by guess and by golly Brian. Whatever works.
Old 11-18-2013, 11:53 PM
That's what I was thinking Dan, thanks.
Old 12-14-2013, 08:16 PM
junkyardjeff's Avatar
I would try a new seal first.
Old 12-14-2013, 08:23 PM
You know, must all of the earlier converts had 3 latches including my 53 Chevy and my 47 Ford. I wonder if there is a practical way to add a 3rd latch in the middle with out it becoming an eye sore. Maybe something that would only be installed when you knew you were going to be on the interstate.
John
Old 12-14-2013, 09:31 PM
Wiki Edits: 27
bug splatter ?
I had a buddy that bought a 59 ford flip top when it was just a couple years old. On a long ride in the summer with the top up the kid in the middle had his white shirt covered with bug splatter. His solution was to roll up a couple pages of a newspaper and lay it on the headder before to top motors screwed down tight for the ride back home.
Old 12-14-2013, 09:58 PM
Banned
could it be, that it was never designed for 75mph..
Old 12-15-2013, 01:43 AM
I am thinking 75 was nothing for that car. At that time there were states like Nevada that had no speed limit on the desert hiways.
Old 12-15-2013, 07:40 AM
Guest
If i bent it, i wouldn't bend it down. I'd give it a slight bend upward so the clamps could pull it tight.
Old 12-15-2013, 11:03 AM
I meant down in the middle, which in turn is bending the clamped area up.
I still haven't touched this guys, I haven't put the top down sense I posted this, been thinking about my truck and it's hard to go back and forth for me.
Headliner bow problem. americanLT1 Interior 3 05-17-2006 03:08 PM
bow tie help pappy1 Engine 4 04-23-2006 08:35 PM
Bow Tie heads 2wld4u Engine 11 07-24-2004 07:34 PM
Convertible Header Bow Cliffrun2 Body - Exterior 2 01-09-2004 11:34 AM
Bow Hunting scott011422 Hotrodders' Lounge 4 05-30-2003 09:03 AM
