Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bowlegged 40 ford mustang II, see pictures
Old 06-04-2010, 11:59 AM
Footstomper Footstomper is offline
Footstomper
Last journal entry: 40 ford/cadillac coupe
When I bought the C.E. bolt-on, the guy adjusted on the top hat with the screw at the highest, and it worked. I talked to a builder, he says it is fine. Or, you could knock off the top to the lower frame and put a 4 by 2 channel under. But looking at what I have now, I don't think I could change it with those wild springs, unless I get a shorter springs.
With as what I have in the pictures, I was told that the springs will settle, it is stiff. The guy says not drive it at over 100 mph or drag races.
Name:	left front bowed springs.jpg
ID:	45960   Click image for larger version
Name:	open the drive.jpg
ID:	45963   Click image for larger version
Name:	The front sits right.jpg
ID:	45964   Click image for larger version
