bowtie heads 14011049 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2011, 06:34 PM
my name is joe morgan, currently finishing a 64 chevyII 4-door car, dare to be different. just traded for a set of alum bowtie heads and found out i am going to need offset rocker arms engine is 385 ran 7.16 @ 99.6 1/8 with world sportsman II heads hope these heads and a 600 lift voodoo cam with 14.5 comp. will get me into the sixes. can anyone tell me what the offset is on the rockers or how to measure to find out.
Old 01-31-2011, 10:09 PM
Hi joe ,got a nickname,suggest you use it.lot of really good guys on here with a lot of experience,however. Idid the same thing.sounds like a fun project.larry
Old 02-01-2011, 12:44 AM
SSedan64's Avatar
I don't think these Heads use Offset Rockers. They only have 180cc Intake ports.
Old 02-01-2011, 12:50 AM
ericnova72's Avatar
More for Less Racer
Unless these heads have had the pushrod holes welded up and the port widened they don't require offset rockers.
You need to give us more info, or even pictures to see what you are doing. If the heads have been modified pics would really help, as an offset rocker could be anything from .050" to .450" depending on port width.
Old 02-01-2011, 07:14 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Depending on the stroke you used to get to 385 cid, and the cam you'll be able to use w/14:1-plus CR you might want to invest in a Jesel shaft rocker set-up. Available in a myriad of offsets and ratios, etc.
Old 08-22-2011, 02:26 PM
bow tie heads off set
Hey Joe ..
My name is Joe as well and I have a similar problem. I currently cracked a head same part number as you are speaking of. I was running normal rockers. I purchased a second set and discovered I am also in need of offset rockers on this set. The difference is the first set had small circular holes for the push rods and the second set has large openings that house both push rods. Problem is the intake ports are too large. Now I too need off set rockers and not sure how much of an off set I need..
Old 08-22-2011, 02:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 427tryke
Hey Joe ..
If you have 049 heads you don't need offset rockers.
Why don't you start a fresh thread for your question so it will get the attention it deserves.
Title it w/a title that gives a good idea of what it is you need to find out- not just "Need Help" or anything general like that. Something like "What rockers for BBC 049 heads?"
chevy bowtie L34 heads? my87Z Engine 30 03-07-2010 03:49 PM
Plugs for bowtie heads Studebaker Engine 0 08-15-2009 05:22 PM
Bowtie Phase II 034 heads? baddbob Engine 1 02-03-2008 10:01 PM
bowtie heads for sbc Eddie Baker Engine 3 11-09-2003 12:02 AM
bowtie stock heads Fireguy0712 Engine 1 08-26-2003 05:50 PM
