box located on back of gauge cluster - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2003, 06:59 PM
spankthru's Avatar
iron head
on my 67 el camino, on the back of the gauge cluster there is a silver box, about 1"x2"x1-1/2" its silver, looks _like_ a relay only writing on it is a "12v" stamped on it, there are three prongs coming out of it, its not hooked up so i cant trace the wires, im wondering what this box is...
Old 06-12-2003, 04:12 AM
New Member
This could be a voltage regulator, some old guage clusters required a stable supply voltage for the instruments, electrical fuel, temp and oil. A regulator was often fitted to the rear of the cluster and had a 12v ignition supply to it, then out of it was a stable 12v (sometimes a bit less) for the guages. This stopped the instruments moving up and down irratically due to charge variations and other loads. With todays improved alternators and charge sytems the supply is usually taken straight from the ignition.
Hope this helps.
Old 06-12-2003, 05:50 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
i HAVE A 66 AND A 67, they don`t have anything like that.
With no wires connected, hard to tell.
Old 06-12-2003, 02:35 PM
spankthru's Avatar
iron head
this voltage regulator sounds like what it would be, but im confident in my new delco alternator so ill probably take it off, troy-curt, cool didnt know you had any elky's, i love working on my 67, its a wickid car
Old 06-12-2003, 04:28 PM
troy-curt's Avatar
Sparkthru;
Check my album, there should be some pictures there. They may not be very good, I`m just learning this computer thing,and sending pictures and moveing them around is the hardest of all.
When I finelly get one sent , I useraly? don`t know how I did it.lol
Troy;
Old 06-12-2003, 04:42 PM
troy-curt's Avatar
Sparkthru;
I`m going to try to atch. a picture????????????
Old 06-12-2003, 04:55 PM
spankthru's Avatar
iron head
sweet ride troy, although im going for the complete opposite look on my camino, no chrome, death iron gray paint job, pure obscene power !
Old 06-12-2003, 05:45 PM
troy-curt's Avatar
I`ll try this again;
Old 06-12-2003, 05:58 PM
troy-curt's Avatar
That last one wasn`t very clear;
This is the eng in the 66 ,355, DZ cam, intake ,holly,dist and heads. 700R4 and 12 bolt pose--373s 4 wheel disc.
Power windows,AC,gauges,floorshift,console,bucket seats,tinted glass.
Compleat fram off every thing new. Drives like a new car.[IMG]dcpoo852.jpg[/IMG]
Old 06-16-2003, 08:39 AM
woodz428's Avatar
Troll Hunter
Arrow
Sounds like constant voltage unit (or regulator) , they were used to keep the gauge voltage level so that they wouldn't fluctuate with the charging current. If the gauges start getting weird (for instance the temp gauge,fuel gauge,oil pressure gauge start getting high readings at the same time, or low) it probably needs replaced. They were pretty common for many years.
Old 06-16-2003, 10:18 AM
troy-curt's Avatar
Must of been on the old generater systems.
