Boxing a 30's chassis - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2008, 09:41 PM
need strog32 chevy front doors
Last journal entry: Tbd
wondering what to do about the boxing on the driverside where the plate meets the steering boxin the pic. i sunk the steering box into the channel . Will weld up the front plate and the rear plate not pictured(two pieces are jjust for mock up) but should i put a reinforcing plate on the vertical side that just behind were the steering box
Old 07-22-2008, 09:54 PM
Last journal entry: Resizing the rear window
Frame boxing
Why not try making a recessed box to go inside the frame right behind the steering box? That way it will be strong and look clean also.
Old 07-22-2008, 10:00 PM
Thanks that will do .
Which Chassis finish would you choose from these 2 options? uglyjeep Body - Exterior 11 10-10-2008 11:17 PM
Use of mini truck chassis under 30's pickup cboy Suspension - Brakes - Steering 0 05-18-2008 10:10 PM
Cutting '30's chassis 31chevy Suspension - Brakes - Steering 2 04-10-2007 10:52 PM
HELP! New 32 Ford chassis issue RoadShow Body - Exterior 8 06-30-2004 06:50 PM
GMC chassis frame boxing Neophyte Suspension - Brakes - Steering 3 05-18-2004 11:31 AM
