boxing frame on '33 plymouth sedan
A friend asked me if I thought he should box in the frame on his '33 Plymouth
4 door sedan. I have not had any experience with frame boxing, so I thought I would put this question out there for him. It has mustang II front suspension and a Chevy small block. He is also thinking about switching to an early Chrysler hemi. He is not sure if the stock frame will be strong enough. Any input from some of you that are knowledgeable in this area would be greatly appreciated. Thanks, Nomadbb |
All MII kits provide the boxing plates for the front end and should be used. Any other boxing could easily be done in the area of the transmission cross member and rear suspension mounting areas if desired. The 33 plymouth frames were very well over designed so I would not concern myself too much unless it is going to be hammered on a regular basic with a lot of HP and torque.
Trees |
| 33 Willys Sedan | Frsnitz | Hotrodders' Lounge | 8 | 11-25-2006 09:39 PM |
| 1938 Plymouth 4-door sedan | mahearn | Hotrodding Basics | 7 | 10-26-2005 08:38 AM |
| Metal prep for frame boxing | Brian Hix | Body - Exterior | 4 | 12-15-2004 12:10 PM |
| 33 plymouth m11 clip into 38 ford? | 38harry | Suspension - Brakes - Steering | 2 | 10-25-2004 03:28 PM |
| GMC chassis frame boxing | Neophyte | Suspension - Brakes - Steering | 3 | 05-18-2004 11:31 AM |
