Boxing the frame of a 56 3100 truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2013, 04:52 PM
Ive got a 56 chevy 3100 pick up that is going to be getting a big block soon. Any suggestions as far as boxing the frame? Fabing the mounts up and boxing the frame is def. work that I can handle myself. Im just curious as to what other opinions are on boxing the frame. I have built jeeps for the last 25 years and I know that jeep frames should not be completely boxed. Should I box just the part of the frame where the motor mounts will go or box the entire front part of the frame? Thanks in advance for any advice.
Old 09-29-2013, 05:17 PM
techinspector1's Avatar
Wiki Edits: 326
GMC division installed Pontiac motors in the '56 with an otherwise stock frame and I suspect the weight is similar to a BBC. So, my question would be....why box it?
Old 09-30-2013, 08:53 PM
ogre's Avatar
the 'Duracell Project'
a little cool factor and the fact these frames flex a lot.
a 56 frame is straight with the exception of a slight bump over the rear axle.
i had some 10 ga steel sheared to fit the frame and welded it in.
i'd suggest replacing the stock x-members and not reusing some like i did.
more c-notch if your going to flip the axle too
my 58 frame
Old 10-06-2013, 08:05 AM
Thanks for the advice fellas. Ill post up pics when I figure out what I am doing. I'm dealing with the steering and headers so I only have to make the motor mounts once. I hope!
Old 10-06-2013, 12:40 PM
ogre's Avatar
you can see my $5 motor mounts in the 3rd picture above or use this type
either way you shouldn't have more than a couple bucks in motor mounts.
Old 10-06-2013, 01:50 PM
If you want to make it look better, if you want to just have fun and do it, what ever, but I can't imagine a need to box the frame on one of these trucks. Not unless you were running GOBS of horsepower and slicks and all that. Big block, the weight means nothing, crap the stock inline six with the stock compound low four speed probably weighs MORE than the big block and a TH400! With my 48 I ran a 401 Buick with a th400 and tires that provided zero wheel spin at the drags turning very respectable 60 ft times never saw one single reason, not even the hint of one to need boxing the frame. And the 55-59 Frame is way stronger and larger than the 47-54 frame. Honestly, I don't think there is any reason to think about it, strength wise.
Old 10-07-2013, 09:40 AM
Thanks, I'm thinking its not going to get boxed but I had to get other opinions. I'm used to building jeeps/rockcrawlers where EVERYTHING is built way overkill.
1950Chevy 3100 Truck Frame chevykid33 Hotrodding Basics 1 06-20-2011 05:06 PM
1950 Chevy 3100 Truck Frame chevykid33 Hotrodding Basics 2 06-10-2011 09:22 PM
boxing a frame racur96 Suspension - Brakes - Steering 6 10-27-2003 11:36 AM
Boxing in a frame 78 monte Suspension - Brakes - Steering 8 09-28-2003 06:20 PM
Boxing Frame BigChevMan Suspension - Brakes - Steering 5 07-10-2003 02:28 PM
