Boxing frame later tonight have a question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2005, 01:53 PM
I will be boxing the frame on the "A" tonight and have the plates scribed and cut perfectly..
I will be setting the plates in about 3/8" to run brake lines ect. and create a "I" beam affect for strength
The plates are 10ga 6' long so there will only be 2 seams
How do you guys hold the plates in their place while welding?
I was thinking of cutting a couple pieces of 1"X2" and welding them to the inside of the frame to rest the plate on, I could also clamp down on those areas to help keep straight.. But I will not be able to weld the 1X2 to the plate once in place, will that be okay?... What do you guys think?
Should I also chamfer the edges to 45 deg. even though it is going to be a fillet weld?
Thank you for your help!
Jay
Old 12-10-2005, 02:06 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Your plan sounds OK to me. I would not go to the trouble to bevel the edge. To keep from warping the rails when I boxed mine I did not weld all at once. I tacked the boxing plate in and I jumped from to to bottom and front to back welding one inch at a time about 6 inches apart. After cooling I repeated the proceedure. This was done over and over with plenty of cooling time until I had it welded continously. My frame never racked or warped any.
Old 12-10-2005, 02:19 PM
Henry to the rescue.. again!... Thanks.
How did you hold the plate exactly in the frame where you wanted it with out letting it fall completely inside until it was tacked?
I had the same thoughts about that welding technique, it's nice to have it confirmed by a guy who knows his stuff!
Old 12-10-2005, 02:24 PM
Lost in the 60's
Wiki Edits: 4
I did not set mine in, I did it flush. But your idea on welding in some stop pieces to support it at the right inset position sounds like a good idea to me. When you get through they will be hid inside of the frame and will not hurt a thing.
Old 12-10-2005, 02:47 PM
Thats what I was hoping to hear!
Thanks for such a fast response!
Jay
Old 12-10-2005, 03:20 PM
Lost in the 60's
Wiki Edits: 4
Good luck with it and have fun!
Old 12-11-2005, 07:31 AM
boxing plates
use a magnet to hold in position
Old 12-11-2005, 07:52 AM
I cut the tubing as I said, and it worked great!
I cut 5 pieces and rested the plate on them and used 5 C-clamps on top of each to clamp it to my jig..
I put 1 piece of tubing just in front of the bend in the frame and 1 piece just behind the bend and tightened the clamps..
The plate perfectly follows the curve of the frame!
I felt like Mcgiver from the 80's tv show! LOL
Thanks again!
Jay
Old 12-11-2005, 07:54 AM
A magnet would not have worked for me...
But thanks any way
Jay
Old 12-11-2005, 07:56 AM
Lost in the 60's
Wiki Edits: 4
Way to go! Glad it worked out for ya.
Old 12-16-2005, 11:15 AM
boxing frame
another thought. When you recessing your plates into your frame rails, you could also use a spacer tacked on the outside of your boxing plate and that one tacked to another piece of whatever, wider than your rail, to keep your plate from going too far into the rails, and when it is all tacked in place, remove them to reuse on the other side. By using this method, you would not have any pieces inside your rails, that may break off and remain in your frame rails to cause rattles in the future. Just a thought.
Old 12-16-2005, 06:12 PM
Good idea....Thank you!
But their already in there.... I welded those puppies solid on 2 sides, if they fall off.....I have MUCH bigger problems! LOL
I will keep that in mind for the next time I do something similar.
Old 12-16-2005, 07:26 PM
frame boxing
I welded those flat 1/4" nuts (for lack of the proper term) to the boxing plates where I was going to place line clamps, then used the threaded holes to hold pieces of angle iron to align the plates. Bill
Old 12-16-2005, 10:40 PM
frame boxing
Whatever works. that is a good idea also. Good luck with the projects.
Old 12-20-2005, 12:16 PM
budthespud's Avatar
Diehard Chevy Guy
I'm boxing my 66 Chev Truck Frame
I'm boxing my frame are you grinding the welds smooth? I am for a clean look.
When you get her done post some pics on this same thread so we can all take a look.
Frame Question. Rubberman2003 Suspension - Brakes - Steering 2 12-03-2003 01:49 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
boxing a frame racur96 Suspension - Brakes - Steering 6 10-27-2003 11:36 AM
Help!! Frame and body question for mustangs 67-68 -=|BR|=-LionHeart Body - Exterior 1 10-09-2003 06:59 PM
Hotrodders Guidelines -- READ ME Jon Engine 0 06-14-2003 04:53 PM
