boxing in rear control arms "HELP" - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2004, 08:27 PM
406 ss monte's Avatar
eat a beaver, save a tree
what is the reason of boxing in rear control arms? i've got a 85 SS Monte Carlo & i've been told i should box them in but not really sure why i should. should i box in the upper & lower, or just the lower control arms? why box them in at all? a engine i know, but i know nothing about supenion's. thanks
Old 02-15-2004, 09:34 AM
astroracer's Avatar
Read this for some info... http://www.gnttype.org/techarea/suspension/chassis.html
I did a search on the web under "boxing lower control arms" and found this as 1 of many hits... Try a search...
Old 02-15-2004, 09:45 AM
poncho62's Avatar
Wiki Edits: 5
Boxing them helps stop flexing and twisting. Also, you should replace your rubber bushings with poly ones....even less flex.
Old 02-16-2004, 09:42 PM
I disagree with welding control arms they are very carfully designed to have just the right characteristics from the factory. Welding on them changes these characteristics
Old 02-17-2004, 08:27 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
All high output cars were boxed from the factory, others were not because they did not have the power to flex them. welding on them will not change the way they ride, just makes them stronger.
If you want a sway bar they will have to be boxed.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 02-17-2004, 03:58 PM
Welding on any metal changes its characteristics if they are boxed from the factory this has of cource already be taken into account. Its a big no no it weld on suspention parts although i know its done quite frequently.
Old 02-17-2004, 06:08 PM
troy-curt's Avatar
How do you think they box them?......They are welded.
If it's done right, you will not change anything.
Troy__________________
Old 02-19-2004, 07:08 AM
wp442's Avatar
Last journal entry: Feb. 03, 2006 - Bed repair 05
I agree...you might not want to be welding on springs, since that WILL effect the temper of the spring steel, but as for the other suspension components, there's absolutely no reason to NOT weld on them. They really have no 'characteristics' to damage, and as previously noted, it's how they were done at the factory as well.
Old 02-19-2004, 07:48 PM
Well interestingly there is alot more engineering that goes into each suspension component than most people realize. control arms are carefully designed to have enough flexibly so that if they undergo a heavy blow such as striking a curb they will generally bent and absorb the impact instead of crack and breaking. when a piece is welded on it often becomes harder and more brittle.
quote: *suspension components, there's absolutely no reason to NOT weld on them*
don't ever write that on an apprenticeship exam
Old 02-19-2004, 07:58 PM
troy-curt's Avatar
I think you have the control arm mixed up with the springs and sway bars. If you bend a control arm, you had better replace it, because it will not come back. There is no apprenticeship form or exam for building hotrods.
If you bend one on a curb, your going to fast in reverse.
Troy
Old 02-19-2004, 08:07 PM
[QUOTE]Originally posted by troy-curt
[B]I think you have the control arm mixed up with the springs and sway bars. If you bend a control arm, you had better replace it, because it will not come back. There is no apprenticeship form or exam for building hotrods.
Troy
I'm talking about mechanic licence cirtification. I realize I am spliting hairs a bit. For very obvious reasons sway bars and springs should never be welded on but idea no suspention pieces should be including tie rods and control arms. As for the comment about "if you bend a control are you better replace it" I'm not sure what you point is
Old 02-20-2004, 12:55 AM
troy-curt's Avatar
quote;
Originally posted by Robison Robin;
__________________________________________________ _
control arms are carefully designed to have enough flexibly so that if they undergo a heavy blow such as striking a curb they will generally bent and absorb the impact instead of crack and break.
Quote
__________________________________________________ __
They will not bend and absorb an impact. The point is, if you bend one replace it. They are not designed to bend or flex.
If they have had the reinforcement welded on,(that we are posting about) and they get bent, it wouldn't make any difference, because the car would probably be totaled.
Tell me what you think a control arm is.
Troy
