Brace Tube Thickness - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2011, 08:52 PM
after i install a step notch on the frame im working on, i was going to run some square bar between the notches to act as a brace and a place to weld on the mounts for the top of the air bags, all i can find in square stock right now is stuff thats .120" or about 1/8" thick, so i was going to get 1" square---.120" wall thickness, would that be strong enough to mount the air bags on? if not, how thick does the wall of the tubing need to be?
starter brace Oldguy48 General Rodding Tech 2 06-16-2010 04:45 PM
How do I put on a starter brace on a 350 sbc? eric32 Hotrodding Basics 5 05-19-2009 07:58 AM
Do I need a X brace in my chassis? Quarter Flash General Rodding Tech 4 04-04-2007 06:28 PM
Starter Brace Novaman78 Engine 13 01-23-2005 08:09 PM
How to fix a CF ankle brace ... aj476 Introduce Yourself 5 10-13-2004 04:34 PM
