Bracing a model A body for replacing wood with steel - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2011, 02:15 PM
Are there any photo's showing how to brace the body before removing wood and installing metal and making other repairs to the body?
Thanks in advance
Old 05-19-2011, 09:50 PM
Wiki Edits: 27
grid and brace.
I did a 29 nash a while back. I used a piece of 3/4 plywood screwed down on a big pallet and had it up on the body cart so it was easier to work on with out bending over. I drew a grid on the plywood to get every thing square and screwed down . I used pieces of scrap conduit to cross and x brace everything. My son is and elect contractor, and scrap is free. brace similar to the picts showing guys chopping a top.
Old 05-20-2011, 05:49 AM
Irelands child's Avatar
Which body style? Year? For replacing top wood, not a problem. Just make up a framework of doubled up 2x6's. If you have to replace the body channels, then you need to do some bracing. These are 'forgiving' bodies, built loose to bolt on to that wet noodle of an OEM chassis. This is a '31 and is not bolted to the chassis. Usually it was on a pair of saw horses with the above mentioned 2x6 framework:
My roadster - built up the same way except I had to make sure the doors were on if it was moved off that 2x6 framework
Irelands child
1934 Chevy (Replacing Wood With Steel) QUESTIONS mistermuscles Body - Exterior 7 05-11-2011 11:05 PM
Old Chevys are full of wood bracing! rgsprint Hotrodding Basics 9 08-14-2007 03:38 PM
replacing wood body structure in the '29 dodge 427v8 Interior 6 02-17-2006 07:34 AM
Replacing wood bracing in cab 35chevy Interior 6 02-07-2006 11:01 PM
How To Go About Replacing Wood With Steel In 34' Chevy? mistermuscles Body - Exterior 7 11-30-2005 07:40 AM
