Bracket Mounting - Non-Acces. Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2009, 04:05 PM
Hi all, Im having trouble finding the correct accessory brackets for my heads.
Car is a 1980 Camaro Z28. Engine is a Chevy 350 with non-accessory heads. Belt driven fan, alternator, power steering. Long water pump. No A/C
As you can see in the pictures, the lack of accessory holes in the heads is causing my alternator and power steering pump to mount at an angle. Obvously this is causing the belts to wear un-evenly, and fly off while im driving from time to time.
So, can anyone point me in the right direction for a low-cost solution? Ive looked around and cant find proper accessory brackets.
Also, i have a tap and die set. Can i drill and tap my own holes? If so, I wound need info on the correct place to drill.
Thanks.
Old 03-05-2009, 04:23 PM
so ive been doin more research, and apparently they are camel hump heads(never heard of them before). I looked at Alan Grove's web site, and found what i needed. However, i dont wanna drop like $200/w shipping on 2 brackets.
If anybody has links they could post me for a cheaper solution(unfinished metal, summit products) that would be great. Thanks again.
Old 03-05-2009, 06:28 PM
ericnova72's Avatar
More for Less Racer
Look here : www.alangrovecomponents.com
Whoops, you've already looked there, but they are very solid pieces.
Maybe get inspired and make your own, I have quite often, I'm a fan of the mid mount style alternator brackets
Old 03-05-2009, 08:26 PM
if you have your old brackets just just try drilling and tapping your heads. i had to to that on my engine for my serp system to work although i only had one hole to deal with.
Skeeter
Old 03-05-2009, 09:33 PM
Last journal entry: Inch each day is ok for me...lol
Got me a Z28 with no accessory holes too...
I am not sure if you are using a serpentine belt or v belt, but I have used additional brackets with the original brackets one to mount to the header like you and the other side of the bracket I extended to the first intake manifold bolt and used a spacer to flush height. The alternator I believe I used the intake manifold bolt flush to the bracket and the water pump. I am putting my motor back together this weekend and will have some pics early week to verify, but I have never broke a belt (v belt) but I use pretty heavy duty belts. Previously I was running close to 350hp soon to be closer to 500.
Old 03-06-2009, 12:02 AM
As everyone said youll have to shell out or make your own brackets, which isnt hard.
As the proud owner of an 80 z/28 with a soon-to-be fully forged roller 417, I said buy some real nice aftermarket heads with the holes and then rip on er
Old 03-06-2009, 05:02 AM
vortec heads in my reserch has been said to be better than the double humps and they have all the accesery holes ready to go.
Skeeter
Old 03-06-2009, 06:39 AM
302 Z28's Avatar
DO NOT attempt to drill and tap the heads for mounting. That is the quickest way to render those heads worthless. Yes some people have gotten away with it, but more heads have been ruined than not. The material thickness of those older heads varied dramatically.
Vince
Old 03-06-2009, 07:57 AM
SSedan64's Avatar
Another tip, Heads with no Accy. holes are setup to use a short water pump. That may be some of your problem.
Old 03-06-2009, 11:09 AM
Speedway motors has what you need the power steering bracket is $29.00 they also have alt. brackets in stock for your dilema.These heads are used quite often in short track racing the crowd Speedway caters to. www.speedwaymotors.com
Old 03-07-2009, 09:32 AM
thanks for all the info guys. i think im gonna save up and buy the good ones
ARG! Help me settle an argument with my dad Malibu73 Engine 49 05-17-2007 01:09 PM
305 Heads fred56 Engine 18 04-29-2007 03:54 AM
What are the best heads to put on a 305? CCR Engine 6 11-06-2004 01:50 PM
Wut set of heads for my set up? Trav Engine 2 10-15-2003 09:45 PM
Where to get alternator bracket for no-bolt hole heads? WheelMan Engine 7 04-03-2003 10:41 PM
