Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - brainstorming an engine build
Old 12-09-2012, 04:32 PM
trillobite trillobite is offline
I found this to be an excellent read during my research: Racing Engine, How to tips
cobalt brought up some good points, if it is a truck, then it should have the ability to pull something, even though I VERY highly doubt I will EVER pull anything above 500 pounds, you never know.
For a truck engine as a general rule, is it 9-9.5:1 for iron heads, and 10-10.5:1 for aluminum heads? I read that running aluminum heads allows you to increase compression by one point. I'm thinking that it would also be a good added insurance to run .035 quench since I do not expect to ever rev above 6000.
thanks for the good advice cobalt
