Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - brainstorming an engine build
  #23 (permalink)
Old 12-10-2012, 03:26 PM
trillobite trillobite is offline
Ok, with a quench of .040 I will have 10.3:1 compression.
Bore: 4.040 (diameter)
Stroke: 3.48
Cylinder Head Volume: 64
Effective Dome Volume: 6
Use (-) for Dome and (+) for Dish.
Deck Clearance: .025
Compressed Gasket Thickness: .015
Number of Cylinders: 8
Compression Ratio : 10.31 : 1
Total Displacement (in.3) : 356.88
Total Displacement cc's : 5850.49
2 FEL Pro Head Gaskets Rubber Coated Steel Shim 4 100" Bore 015" Comp | eBay (head gasket)
New Small Block Chevy 350 IMCA Claimer Racing Oil Pan | eBay (oil pan)
PRW SBC 305 350 Chevy Sportsman 8" Polished Harmonic Balancer | eBay (damper)
350 Chevy Short Block Assembly High Performance w Forged Pistons | eBay (they may be in the build process as we speak, they are willing to do any deck height I choose)
I can either use that .015 gasket (sounds too thin for aluminum heads) or I can tell them to deck the block to .000 for my Fel Pro 1003 .041 gasket.
