Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - brainstorming an engine build
  #26 (permalink)
Old 12-11-2012, 07:35 PM
trillobite trillobite is offline
Thanks a ton, makes perfect sense, I shall let him know!
A .060 bore will bring me to 10.36:1 compression, crossing my fingers that everything will come together perfectly, all the numbers look excellent.
I will send him this: "Ok, looks good as long as the margin of error is with the piston below the deck, not out the top; Both decks match, each corner of the deck is the same, and the final cylinder bore will be .060."
