brainstorming an engine build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-09-2012, 05:40 PM
Originally Posted by gearheadslife View Post
iron always makes more power than alum..
alum is just easier to cast..
nascar engines make over 80 hp with iron over alum.. but are a one race deal.. when they qualified and pulled engines then ran another in the race iron was the ticket.. but where a one and done part..
That is interesting, you would think that the added compression, cooling, and reduction in weight would have made all the difference.
  #17 (permalink)
Old 12-09-2012, 05:46 PM
gearheadslife's Avatar
MentalMuffinMan
thats the thing.. today.. people get the idea alum makes more because they run higher compression..
but a 12 to 1 iron headed and the same engine with alum heads..
if both the same in everyway other than heads casting material..
the iron wins everytime..
if you got the fuel..
e85 if they'd cast say dart pro ones in iron.. would rock
  #18 (permalink)
Old 12-09-2012, 06:13 PM
Old & Furious
What?? Nascar uses alum heads some classes are limited to cast iron but sb2 heads are alum castings. These are 12 degree heads not normal 23 degree.
24502559
Are you talking about bowtie heads certainly not nascar worthy but used in all types of circle track racing.
12480034
Aluminum is not easier to cast it also is much more expensive. Alum heads transfer heat way batter than cast so you can run higher compression on hotter day out and still avoid knocking if its tuned right of course. Cast is usally a full point lower in compression and still stay in the safe range.
  #19 (permalink)
Old 12-09-2012, 07:42 PM
MentalMuffinMan
iron makes more power hands down.
alum is easier to cast/machine/etc and why they use it..
pore the same heads in both, iron will win everytime
heat = power, alum transfers it, iron holds it..
with a fuel that not pre ign. iron all the way..
r09 engines heads where taken by nascar that where iron.. because the walked over the field
team fined 100k
  #20 (permalink)
Old 12-09-2012, 07:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I found this to be an excellent read during my research: Racing Engine, How to tips
cobalt brought up some good points, if it is a truck, then it should have the ability to pull something, even though I VERY highly doubt I will EVER pull anything above 500 pounds, you never know.
For a truck engine as a general rule, is it 9-9.5:1 for iron heads, and 10-10.5:1 for aluminum heads? I read that running aluminum heads allows you to increase compression by one point. I'm thinking that it would also be a good added insurance to run .035 quench since I do not expect to ever rev above 6000.
thanks for the good advice cobalt
I would call your estimate of "9-9.5:1 for iron heads, and 10-10.5:1 for aluminum heads", safe. I would not, however, want you to go any closer than 0.040" quench. 0.035" leaves NO room for error on the part of the machinist or the dimensions of the parts or even a missed shift or broken driveline part, there's nothing of any real substance to be gained from the extra 0.005", and the downside can be expensive.
While it's true you can usually get away w/more compression using aluminum heads, this is only because aluminum sheds heat easier into the cooling system. There are no free lunches- if you build w/alum. heads, the added compression is needed just to stay even w/an iron head- not that aluminum magically allows you to run more compression. I don't much care for aluminum heads on a SBC daily driven vehicle myself, I like good ol' cast iron. That's not to say the good aluminum heads aren't good- they are- but you do pay for the privilege.
In the same vein, I also never build a street engine right on the edge, compression-wise, either. The general rule of thumb on compression is one point- like going from 9:1 to 10:1- will net you about 4% more power, all else being equal. Now, that IS 16 hp on a 400 hp engine, so isn't exactly insignificant, but the down side to the added compression can be a huge loss of power if you misjudge things and you end up needing to retard the total timing from what gives you the best power- just so the engine doesn't detonate. And it has other downsides as well like less tolerance to a bad tank of fuel, or something that causes the coolant temp to rise past normal. At least in the last two cases you can stop, get out, and turn the distributor to lower the timing to limp home w/o ruining the engine- as long as you caught it soon enough.
My bottom line is: There have been a LOT of VERY strong running SBC 350/360s built using 9-9.5:1 CR. A properly spec'ed and assembled engine w/that CR can expect to make more power than you can safely use on the street. A racing engine is another animal altogether and the two (racing engine on the street) seldom meet happily in the middle, in my experience. Again, that's not to say there aren't 10:1-plus iron head or 11:1-plus aluminum head engines being driven on the street every day, w/o issue. But it IS to say that if you choose to run on the edge, it can bite you.
So I cannot in good conscience advise anyone to build a 11:1 aluminum or 10:1 iron head engine for street duty. When the parts on hand absolutely HAVE to be used, sometimes this means compromises must be made- I understand this. But if at all possible, hedge your bet to the safer side rather than the "faster" side.
Good luck.
The Following User Says Thank You to cobalt327 For This Useful Post:
trillobite (12-10-2012)
  #21 (permalink)
Old 12-09-2012, 08:20 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Some things I forgot to say. Main thing: Stick to the fundamentals.
Insist on a torque plate final hone. A good, round cylinder w/a piston that has the correct piston to wall clearance, along w/the correct ring end gaps will do as much for performance as a LOT of other "racing" tricks. What guys fail to realize is, while a loose piston to bore clearance may have less friction, the rocking motion this allows causes the ring seal to go away.
Follow the manufacturers specs for piston clearance, ring end gap, etc. Measure the piston where the manufacturer says to measure it.
Use a three angle valve job. Backcutting the valves is sometimes a cheap way to increase flow where it'll help on a day-to-day basis (look at what GM did w/the Vortec valves- they do NOTHING "just because" ).
Break in the cam correctly.
There are other things but these are fairly important IMHO.
  #22 (permalink)
Old 12-09-2012, 08:28 PM
MentalMuffinMan
plate hone, with bolts or studs being used on engine, and main caps torques if poss.
  #23 (permalink)
Old 12-10-2012, 03:26 PM
Ok, with a quench of .040 I will have 10.3:1 compression.
Bore: 4.040 (diameter)
Stroke: 3.48
Cylinder Head Volume: 64
Effective Dome Volume: 6
Use (-) for Dome and (+) for Dish.
Deck Clearance: .025
Compressed Gasket Thickness: .015
Number of Cylinders: 8
Compression Ratio : 10.31 : 1
Total Displacement (in.3) : 356.88
Total Displacement cc's : 5850.49
2 FEL Pro Head Gaskets Rubber Coated Steel Shim 4 100" Bore 015" Comp | eBay (head gasket)
New Small Block Chevy 350 IMCA Claimer Racing Oil Pan | eBay (oil pan)
PRW SBC 305 350 Chevy Sportsman 8" Polished Harmonic Balancer | eBay (damper)
350 Chevy Short Block Assembly High Performance w Forged Pistons | eBay (they may be in the build process as we speak, they are willing to do any deck height I choose)
I can either use that .015 gasket (sounds too thin for aluminum heads) or I can tell them to deck the block to .000 for my Fel Pro 1003 .041 gasket.
  #24 (permalink)
Old 12-11-2012, 06:42 PM
Got an interesting email from the builder.
"Just left the shop and wanted to run some things by you. The only 79 down 4 bolt at the shop is a .060 over, let me know if that's alright. Also, the owner (Barry) said that with the stock block, crank, etc. He can only guarantee a 0" - .0035" margin between cylinders on zeroing the block. Shoot me a note when you get a chance."
Usually I would think that a .0035 margin as insignificant since it is such a small number. Is that good, bad, or ugly?
I asked him if .060 will be the final bore, if it is, I don't see it as a significant issue, I have a triple pass aluminum radiator, high-flow aluminum water pump, and I assume aluminum heads will help out a tad too.
  #25 (permalink)
Old 12-11-2012, 07:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
IMO you're OK w/those numbers, given the circumstances. As long as the "-" is the piston down the hole, not out the top, and that both banks match, and that each corner is the same- all within reason of course.
  #26 (permalink)
Old 12-11-2012, 07:35 PM
Thanks a ton, makes perfect sense, I shall let him know!
A .060 bore will bring me to 10.36:1 compression, crossing my fingers that everything will come together perfectly, all the numbers look excellent.
I will send him this: "Ok, looks good as long as the margin of error is with the piston below the deck, not out the top; Both decks match, each corner of the deck is the same, and the final cylinder bore will be .060."
  #27 (permalink)
Old 12-11-2012, 09:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
He has the pistons, right?
  #28 (permalink)
Old 12-11-2012, 09:57 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Stroke: 3.48
The default gasket for aluminum heads is the Fel-Pro 1003. Don't use the shim gasket.
The 0.0035" variance is reasonable, considering that he may not want to spend the money to equalize rod lengths, etc. Like Cobalt said, make sure the tallest stack is at zero and the shortest is 0.0035" down in the hole.
Any used flat tappet cam and lifters are junk. You would have to re-use the very same lifter in the very same lifter bore, not in a different block. What do you think the chances are of 16 lifter bores on block #1 being bored exactly the same on the x and y axis and each one the same distance from the flywheel face of the block as 16 lifter bores on block #2?
Why would you spend 62 bucks for a Fosdick 5-quart oil pan? I doubt that it'll seal as well as a bone-stock production pan. If you want to make a difference, use a larger pan. 7-quart is a nice size for a street motor. Get the windage tray and crank scraper. Be very cautious about fitting the screen to the pan. You will need about 3/8" clearance. Less clearance can cause the pump to suck the bottom of the pan up against the screen and cut off oil supply to the pump. More clearance can cause the pump to run out of oil.
  #29 (permalink)
Old 12-11-2012, 10:07 PM
All true, I will use the cam the engine comes with, I keep forgetting to ask him what cam it will come with, and yes, it comes with pistons, rods, crank, timing chain, lifters and the cam.
  #30 (permalink)
Old 01-23-2013, 06:40 PM
Well, the weekend is coming up, the short block has arrived! Took a few weeks after it arrived to get everything situated back at my house, had to pick it up from my work in order to get the good shipping.
One final question before I begin the build and start a thread on that. For some reason I did not think to request the type of cam for the engine builders to install, so it came with an Engine Pro MC1730 with Duration @.05 = int204, exh214, and int.422, exh.444 Lift. The duration seems a little low for 10.3:1 compression, would it ping with this cam, or am I ok as I will have a good quench and aluminum heads?
For just in case that cam will not work, I purchased a comp cams, and cam assembly lube (that I can return) CS 280H-10 Duration @.05 = 230, Advertised Duration 280, valve lift .480.
I can also get an Edelbrock RPM series, and I believe that one had about 245 duration at .05 and 305 advertised, but I figured that would be a bit over-kill.
Let me know what you all think, I can return this comp cams next week for a different one with even more duration, or less, I simply got one so if it is correct I can get my pushrod length measured, and next week can have things moving along smoothly.
Thanks.
350, 383, brainstorming, build, engine
4 banger brainstorming (help me out) Nonhog Engine 28 02-18-2012 11:26 PM
My engine Build Ozz1967 Engine 8 07-07-2008 07:44 PM
Engine Build Chevyboy_0 Engine 20 04-17-2008 03:24 PM
Brainstorming PhillyMisfit Engine 2 02-09-2007 10:49 PM
brainstorming next car, small 5-Speed V8 WayOutCat General Rodding Tech 16 05-20-2003 07:16 AM
