Brake - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2010, 07:28 AM
Brake
I just purchased a 1952 Dodge Wayfarer Coupe and found the right passenger brake drum is cracked. Can't seem to find a replacement, but what I am really looking for is a disk brake conversion kit.
HELP
Old 08-22-2010, 08:25 AM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I do not think you will find any bolt on conversion kits, unless the brake system is shared by another model and year as your car, manufacture specific. That said the good news is cars of that era usually had a year 10 run before any major changes were made. Nun the less you will have to the research it will not be something welwood or bear will offer as a kit.
On the drum angle you could take the measurements and maybe come up with a replacement part. Diameter of course, the brake shoe contact area/ with, and the axle hole, lug nut pattern understood . Welcome to a great hobby and get ready to learn .
Old 08-22-2010, 08:47 AM
27 t's Avatar
WHO WHAT ME WAIT I DON'T KNOW.
Last journal entry: Door skins removed
HELP
maybe this link could help if it's still good...http://www.collectorcarsforsale.com/...390415186.html
Old 08-22-2010, 09:04 AM
Thanks
THANKS FOR TAKING THE TIME TO GIVE ME SOME DIRECTION.
Old 08-22-2010, 09:05 AM
Thanks
Thanks For Taking The Time To Direct Me In The Right Dirction.
Old 08-22-2010, 09:14 AM
27 t's Avatar
no problem good luck hope it works out...
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Advices on brake system repair 78 Monte rack Suspension - Brakes - Steering 5 01-12-2009 08:32 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
