brake bleeding - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2005, 10:22 PM
mitmaks's Avatar
Last journal entry: Grille
brake bleeding
Ive read magazine and it suggests to use this brake bleeding sequence
left rear wheel
right front wheel
right rear wheel
left front wheel
always thought it was farthest wheel (from master cylinder) first
This is from MOPAR magazine
Old 10-27-2005, 12:08 AM
abstruse dutch uncle
Is that for a front wheel drive car?
Most bleeding sequences seem to boil down to bleeding the wheels attached to the front master resivoir first. On some, that's rear to front, on others front to rear, and some go crossways. Most old MOPAR muscle cars use the front resivoir for the rear brakes, so I would assume farthest to closest.
I always was bleeding the old GMs furthest to closest until I read through the factory service manuals. Most of them say front first until about 1980 when they swapped ports on the master, or went to the cross system on FWD models. It seems to help get the air out faster.
Essentially, it doesn't really matter, as long as you get all the air out. If you have trouble with one wheel or axle, skip it until you do the others. I often hit each wheel one more time when I'm finished anyway.
Works for me.
Brake bleeding made easier jimfulco Garage - Tools 18 07-15-2007 12:16 PM
one-man brake bleeding atlantis Suspension - Brakes - Steering 20 08-25-2005 12:54 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
brake bleeding with pressure 73chevyhelp Suspension - Brakes - Steering 8 05-20-2004 07:55 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
