Brake Bleeding HELP!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2007, 09:51 AM
Last journal entry: comming along
I am bleeding the brakes on my 37 Ford. I bought one of those one-man- brake bleeding systems. I have to bleed the master cylinder first. I took off the lines running to the master. I put scrap lines that I have on in place and put them into a gas jar to check for air bubbles. I pumped the brsake, and fluid is comming out great out of the rear line.. No bubbles. The front lines only drip. I tried crimping off the rear scrap line to force mor pressure to the front. Again. Only a drip.. Am I not doing something right?? thanks.. Al
Old 03-24-2007, 01:24 PM
Given that you are talking about a '37 and a tandem master cylinder I am going to guess that it is not the stock master. What is the master cylinder from?
Old 03-24-2007, 02:21 PM
Sorry.. I was able to fix it myself.. I had another master cylinder that came with the car. I just replaced the master, and it works fine now.. Thanks for your help though.. Al
Brake bleeding made easier jimfulco Garage - Tools 18 07-15-2007 12:16 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
one-man brake bleeding atlantis Suspension - Brakes - Steering 20 08-25-2005 12:54 PM
brake bleeding with pressure 73chevyhelp Suspension - Brakes - Steering 8 05-20-2004 07:55 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
