Brake Bleeding-Non Stop Air Bubbles - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-01-2009, 06:51 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
The mechanic pressure tested the system and found a leaking rear brake line.
We couldn't see any dripping or leaks when it was up on the hoist.
I've never seen a brake system pressure tester.
Anyone know how this device works?
  #17 (permalink)
Old 03-01-2009, 03:57 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Originally Posted by eloc431962
bryan59EC is this do to the route of the lines?just trying to figure out how the left rear would be the furthest from the mc. cole
Line routing
leaves the master cylinder to a block on the left frame rail that feeds the left front wheel and continues to the right side of the car.
Another block feeding the the right front and continuing to the right rear frame rail to 'right of center' of the differential.
The left rear brake line is about 3' long vs the passenger side 18"
Even with the disc brake conversion lines----the rear line runs parallel to the front lines to the passenger side.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
Bleeding New Brake Lines scotzz Suspension - Brakes - Steering 5 02-22-2009 07:05 PM
Help!! Air bubbles under the hood decals!! mrobby440 Body - Exterior 3 05-06-2007 09:46 AM
Easiest One Man Brake Bleeding Job??? Steve-0321 Suspension - Brakes - Steering 9 06-05-2004 04:12 PM
'57 bel air disc brake conversion mitmaks Suspension - Brakes - Steering 1 12-20-2002 08:22 PM
