Brake Bleeding-Non Stop Air Bubbles
I have a friend with a 98 Blazer.
He found his brake fluid low after his brake light came on. He's bleeding the front brakes and the air bubbles keep coming non stop. There is no apparent leak anywhere that can be seen. Any thoughts anyone? |
why just bleeding the front?Iwould go and bleed them all just remember to start bleeding on the furthest wheel and work your way to the closest to the mc. the fluid could be by passing through his booster also. cole
Only the front was low.
I encountered the same thing on a Mercury Tracer. I did the rears first and then the fronts wouldn't bleed without air bubbles. He left my place, got down the road about a mile and called to report his brakes were working.
are you using a pump or gravity bleeding ? if you are using the pump do the gravity bleed it always works for me. cole
He was using the vacuum pump.
He's gone to take it to a mechanic. I'm thinking its the master cylinder allowing air in somehow? We'll see what the mechanic does and post back. Thanks. |
Interesting. Can you fill me in . What is a diagonal braking system? |
It used to be that split hydraulic brakes (dual reservoir) were split between front and rear brakes. Newer tech has gone to diagonal whereas the left front and right rear are energized (and vicey-versy) from one of the split reservoirs to provide more stable braking in case of a partial hydraulic failure. This is more common twith he FWD and possibly anti-loc but it is a good idea to determine how the car was built.
Trying to bleed a new system as an old system will lead to much frustarion and beer abuse...
makes sense to me now.have to check when bleeding brakes.instead of the old way RR/ LR /RF/ LF.the newer diagonal way will be RR/LF/LR/RF.It all makes sense if you are having trouble bleeding the brakes you need to know which system you have.thanks Kultulz we are never to old to learn.
VAC BLEEDING are the bleeder screws rapped with Teflon tape ?
will suck air by threads when you loosen them . same if you use the hose in bottle of brake fluid and pump brakes method. |
If you look at a set of speedbleeders, they come with sealant on the threads already, so they don't suck air back in on the upstroke. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
bryan59EC is this do to the route of the lines?just trying to figure out how the left rear would be the furthest from the mc. cole
| larger compressor | gburgess2002 | Garage - Tools | 13 | 07-19-2009 09:36 AM |
| Bleeding New Brake Lines | scotzz | Suspension - Brakes - Steering | 5 | 02-22-2009 06:05 PM |
| Help!! Air bubbles under the hood decals!! | mrobby440 | Body - Exterior | 3 | 05-06-2007 08:46 AM |
| Easiest One Man Brake Bleeding Job??? | Steve-0321 | Suspension - Brakes - Steering | 9 | 06-05-2004 03:12 PM |
| '57 bel air disc brake conversion | mitmaks | Suspension - Brakes - Steering | 1 | 12-20-2002 07:22 PM |
