Brake booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2002, 12:16 PM
mac mac is offline
Post Brake booster
The inlet side has a filter and a screen,no way to connect anything to it. Thanks anyway for the reply. madmacs34@earthlink.net
Old 06-24-2002, 06:08 PM
WoodsEdge's Avatar
Post
Hey Mac, a brake booster works by the engine or vac pump sucking a vac inside the chamber, it has a rubber diaphram that helps activate the master cyl with less foot pressure. Is your pump sucking vac or building pressure???
Old 06-24-2002, 07:55 PM
mac mac is offline
Post
woodsedge,I took the filter and screen off and using the inlet side to create vacuum. It seems to be working but I'm not sure if this the correct way to operate the pump or if I'll damage it. I'm going to run it like this and see what happens. Thanks for the e-mail Mac
Old 06-26-2002, 02:43 AM
SJFast's Avatar
Post
Exactly what I said in reply to your original post.
