Brake Booster
Good Morning Guys and Gals
I believe I have a bad brake booster, or at least a vacuum leak in the booster, however it still seems to work, and I have power brakes. The issue is I hear a continual hissing which gets worse as I step on the brake pedal. When this first started happening it wasn't making noise all the time, it only happened when I stepped on the brake pedal. I know the vacuum line runs outside the cab of my 87 Bronco, but this hissing noise is definitely coming form inside the vehicle. I would have thought with that much loss of vacuum (if that is what it is) it would be acting like I have manual brakes. Any ideas or explinations? Thanks for any help you can give me... |
I would put a vacuum gauge on it and see how much vacuum you actually have ...
You need to replace the booster. It has a leak in the diaphragm. The hiss you hear is air being drawn in through the valve that allows atmospheric pressure to the booster.
| 1997 blazer..Brake booster gone bad? | RodFather | Suspension - Brakes - Steering | 2 | 06-17-2005 01:26 PM |
| brake booster size | pigjamelectric | Suspension - Brakes - Steering | 3 | 05-08-2005 08:44 PM |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| Power brake booster hissing | jrm123180 | Suspension - Brakes - Steering | 2 | 03-19-2004 08:59 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
